Help on buying a used ML320
I'm looking at a 1999 ML320
No leaks visible on the undercarrage of the car tranny, engine, all seemed dirty but no oil build up.
No funny noises when driving.
Need to check for noises during parking lot driving.
Brakes a little spongy?
Compression test
cyl Dry Wet
1 --178-- 206
2 --180-- 202
3 --185-- 204
4 --190-- 210
5 --192-- 207
6 --190-- 203
Do this numbers look good?
Thanks in advance
A
How much does it cost?
How much mileage?
* Check the car fax not that it will do much =\ *
I'd prefer an 02+ ML for a cheaper + safer decision, if you buy a 99 ML your going to spend the difference in repairs plus lots more + time repairing.
It cost $9K.
1 owner.
95K miles.
With the exception of a couple of blemishes the exterior and interior are in very good condition. Not excellent but very good.
A
But you can look at it this way, it maybe cheap for a reason.
Your Welcome, I hope my opinion helps you out in your decision.
These pro's on the MB site should help you out once they get on. They can explain to you what you are in for and what kind of problems you will run into and if its a good buy.
PS: Make sure you have extended warranty that covers a real good amount of mechanical problems, it always helps. I would never consider without warranty (My personal opinion, and most people would say).
Only two concerns with the car.
1. Tranny because of what I've read... anyway to tell if it's on its way out?
2. Some old oil on top of the valve cover not the plastic engine cover. It wasn't the sides but coming off the top close to where the spark plug hole is. I couldn't take the plastic engine cover off to see where it was coming from.
I have seen mercedes from decades ago that never had tranny or engine issues. I have seen a 2006 S500 on the road with a broken tranny.
Point is, if you like it, buy it. Hopefully you will not regret it. Remember, you ARE buying a 9K car. That said, even a 9K Accord will have its issues at times. People preach lexus and Honda reliability, I had a 2000 model accord break tranny at 46K miles (fixed under goodwill by hond though).
Just make sure you and your mom likes the ride. I traded an E420 for the truck, and am still adjusting to the ride and the smaller engine.
On that note, GOOD LUCK. Hope you get it and it behaves
Most of the basic maintence on the car would be done by me. Oil, coolant, plugs and would do this weekend. The tranny per recommendation from this board I would let MB do it.
The parts cost and as you said minor things is what concerns me. This vehicle will essentially be my mom's car. That being said she doesn't have the money to replace big ticket items such as trannies.
I'm starting to lean towards not buying it. Although, I have the cashiers check in pocket, the thought of major repairs or frequent minor ones causes me concern
Victor
Victor
Thanks for all the input guys. I'll see if I can find a good quality '02 for my Mom that won't break the bank.
Victor
Wise decision!. My impression is that MY2000 is the entry for a light wallet, and +MY02 is if you have the budget. Like already mentioned the 2 major changes happend in MY2000 and MY2002. Although the tranny has the same partno it also has internal design changes with time. That means a younger tranny will not be better because it has less miles on it, but also be less prone to failure as it has optimized design changes from previous failures incorporated. i.e a 722.663 transmission from a MY2004 is better than a 722.663 from a MY2000 due to internal changes...
You have enough support on this and other forums on the tranny issue (even a +02 model might have problems). Enough of us have done it (including myself). I did a DIY writeup, and we are using it (hopefully enhancing it with input from other replacements in the future).
I doesn't seem very hard to do yourself (as long as you have access to a car lift & support stand). The real trick is to either buy a cheap replacement or second hand transimssion (depending on your wallet) when it goes wrong. The main thing with the tranny is to frequently change the Fluid to prolong the life of it.
