Help Looking for a lil Preformance Need advice.
Im looking into getting some preformance out of my ML
I was thinking green filters but dont know if they make them for my Ml im sure they do im going to check that out right now
i was also looking to remove the resonator. Has anyone done this? and how does it sound
and i was reading about SpeedTuningUSA
anyone know if the make a chip for the ML and is it a noticable difference?
Thanks for reading guys your help is much Appreciated
I have it on my Ml500, dun expect hp gains, (other option is theres things like ITG cold air cone filters)
resonator wise, back a few months they were selling a bunch of supersprint resonators for the W163.
chip wise, check powerchip.
i'm pretty sure u can do a lot more, but i leave my ML's performance pretty much stock.
well if it wont help the preformance at least it will on the gas milage haha
im in NY also .. where did you get the filters and also i want to remove the resonator from the stock exaust just for the sound its an AMG btw so it sounds alright i would just like it to be a bit more aggressive.. any idea about any shops in the NY area that would remove it for me? and how much.. thanks alot brotha...
BTW i have an ML 55 not to confuse anyone cuase i didnt mention it before.. at least i dont think i did
Do underdrive pullies(evo sport), Custom Exhuast(previous owner had everything cut off and had a magnaflow muffler put in, sounded sick) I recently had pipe bent up for an intake, I need to fabricate a bracket for it, Also do a power chip ECU
Best bet is to just stick with messing with the muffler... I would not advise messing with the air intake since doing so my actually result in HP and TQ loss. The ML intake was build very long for a reason to increase low down HP and TQ. Some people with modified air intakes have had MAF troubles from having the MAF become dirty often and needing to be cleaned to having MAF damaged and needing to be replaced.
Back to the muffler from what I have read most people go to a local muffler shop and buy and have them install it.
couple things.
where can i buy the magna flow?
can i put back on the OEM muffler?
if i want to just remove the resonators where are they under the car?
ive read that there are 2 im talkin about the ones closest to the rear of the car
thanks bud
my set up had resonators removed and muffler removed...
I'm working on offering ypipes and bolt in center replacement mufflers very soon. The one for my '55 is on the way but I need a center muffler off of a 320 and 430 as they are different part numbers. So if any of ya'll have replaced them and kept them around, let me know how much you want for them.
