Fog Light Help
Old Sep 22, 2006 | 10:47 PM
Riffyb's Avatar
04 S500, 05 Jeep GC, 06 Acura TL, 04 BMW 530i, 98 Jag xk8,
Exclamation Fog Light Help
so i got my projector foglights in.. but.. my fogs arent working.. the light on the cluster is on but no output from the fogs? im pretty sure it was like this before i started to swap out the lights... today i tried to connect and cut and splice wires whcih i did on the passengers side and connected it.. left side was still oem fog.. but stil no luck both sides are out.. any ideas? maybe a fuse? is there even a fuse for the fogs? and where is it? thanks for the help
Old Sep 23, 2006 | 09:55 AM
Riffyb's Avatar
any ideas??
Old Sep 23, 2006 | 10:09 AM
AsianML's Avatar
2007 E63
Can't help you, but the fuse box in the passenger footwell area. There are two big plastic screw looking things that you'll need to turn.
Old Sep 23, 2006 | 10:30 AM
Riffyb's Avatar
i checked there but no fuses for fog lamps..
Old Sep 23, 2006 | 06:17 PM
dewdaltz's Avatar
02ML320/06R350
Open the hood, on your right side next to the plastic windsheild washer there is that black cover thing open that and you will all the other fuses. And on that cover you will see the diagram with their respective fuses. hope this helps.
Old Sep 24, 2006 | 08:19 PM
Riffyb's Avatar
thanks alot it was the fuse.. i bought the 65w lights even tho the car uses
55w bulbs... i could always change the bulb ? right? or can i change the fuse would that do anything? also.. i took the old wire from the old fogs and the wire harness that was already there cut and added them together then added the connectors at the end. will this cause a problem or is that ok? i need to wrap the wire in electrical tape but will this cause any hazards?
Old Sep 25, 2006 | 03:21 PM
AndrewAZ's Avatar
BMW FTW
You could go with a stronger fuse, I would not be that concerned about the wire since I am sure it they did not use a 65w wire for 55w stock bulbs my guess is its a 75w cable, if not then you might want to replace the wires.
Old Sep 25, 2006 | 04:52 PM
Riffyb's Avatar
thanks alot AndrewAZ its at the shop right now.. getting installed... after its done.. ill have to decide if i want to swap them for xenons... anyways.. ill post some pics tonight of my new updated lighting... Projector Fogs..6k philps bulbs and the LED turn signals...
