Injector #6 shuts off @ 5000RPM on ML320
Press the pedal to kick down in gears and reach approx. 5000 RPM, I have determined that the injector for cylinder #6 closes.
Under normal driving, I have determined the injector works fine.
did all the things like:
replacing crank shaft sensor
replacing MAF sensor,
replacing spark plug and lead and coil pack
checked wiring loom
PLEASE.... any solutions?
Tomorrow, the mechanic is fitting a new "computer" which he has borrowed from somewhere.
I will post the outcome of this trial....
Benz dealer did run STAR. Output from it referred to failed injector with possible cause of failure to the catalyctic converted if injector problem persists.
Just spoke to the mechanic who advised there was no apparent fault with the engine - when he drove it cold 1st thing in the morning.
Cylinder/injector reverted to faulty after the car's initial warm up.
PLEASE.... any clues here??????????????????
Injector from #6 was swapped to the opposite cylinder bank but still the problem existed in cyl #6.
If valve was slow etc, would compression reading be erratic or could it still read normal?
Fuel pressure test showed up ok.
checked wiring loom
You are activating the REV limiter when you rev the engine past 3000RPMs while the vehicle is in park......
I have not tried to simulate the problem whilst the vehicle is in Park.......??????
I really dont know what that meant.
To get back to your problem, what gave you the clue and how did you determine that it was the fuel injector cutting off at the specified RPM??
The mechanic who first looked at the ML concluded the spark plug failed in cylinder #6 - ande he tried all sorts of swaps and re-tries by, for example, swapping plugs, swapping coil packs, swapping crankshaft sensor, MAF.
All to no avail.
He raised his hands in resignation.
Last MJonday I took the ML back to the dealer who sold me it 3 weeks earlier; he still has it.
It is his mechanic who diagnosed #6 injector was not ejecting fuel at revs over 5K.
He will, today, I think going to swap the O2 sensors from left bank to right bank and vice versa.
He has done an exhaust analysis and advised emissions were normal - I presume this test would have picked up any cat blockage.....
2000 ML 320- cat blew out weld failure at about 45k miles
2002 ML320- cat again weld failure at about 57k-59k miles
2002 ML320- going in for service to get 1 cat replaced 36k miles
I think part of the reason might be the location very close to the engine so they warm up fast to reduce pollution, well that fast warm up seems to be the cause of many Cats failing due to cracks vs having them get clogged. I think if you took a poll of people who have had Cat failure my guess would be 90% + had them fail because of cracks vs getting clogged.
If you go look up about the ML one of the "notable" items they brag about is being ultra low emissions due to the placement of the Cats close to the engine so they warm up fast.
