Help!! Installed Navi in 05 ML but no go :(
2005 ML350
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Help! I just got done installing a Navi unit in a 05 ML350 - the actual install was quite easy (read some posts here that helped a ton - thanks folks) but that is when my troubles started.
Now the unit powers on, take in/ejects disks but just does not play anything. I tried a regular CD and that does not play neither does the Navi disk. Once the Navi DVD is in - it still thinks it is a music CD and says insert NAvi disk but doesn't do anything.
Any help is greatly appreciated. Thanks.
Also, the face plate does not automatically close when a CD/DVD is inserted - as it does when I insert a cassette - not sure if this is linked.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
If I remember correctly I do not believe that the face plate will close automatically when a DVD is inserted. Did you install the correct part number for an 05?? Was it purchased used?? Could be a bad unit. Could be that the car has to be programmed to know the unit is there by a dealer. Is the antenna connected correctly?? You have lots of possibilities for your problem, Good Luck.
'11 C300
Wierd. I installed my NAV DVD in my '03. Bought it on eBay. Other than no voice until I had it "version coded" at the dealer (about $100) the NAV actually worked right away. I didn't try a CD prior to having it coded so can't help you there. You do have to push the button to close the screen. It doesn't close automatically when you put in the disk.
