Oil Looks Like Peanut Butter???
Old Feb 25, 2007 | 07:48 PM
Billiken's Avatar
ML320
Today the oil light went on (briefly) in my 2000 ML320.
It's about 500 miles to the next oil change and the car is 6.5 yrs old.
I'm fairly regular about checking the oil level.
No visible leaks or stains on the garage floor.
Sure enough, this time the oil was at the minimum line on the dipstick.
When I opened the oil cap it looked like there was peanut butter on the underside.
It was not as thick, and maybe a shade or two lighter in color.
It was "slippery" like oil and went black when I rubbed it between my fingers.
Should I be worried???????
Old Feb 25, 2007 | 08:53 PM
boxboss's Avatar
? I would be. Oil can be dark, or thin or used looking, but shouldn't look like peanut butter. Any chance they used Quaker State at your last change? A mechanic told me 30 years ago that QS had a tendancy to turn to "butter" over time. He could always tell when someone used QS in their engine. This is just a WAG, but would be interesting to know - of course, oils have changed in the interim.
Old Feb 25, 2007 | 09:24 PM
evdok's Avatar
CHIPPED E320 CDI
Head gasket?
Old Feb 25, 2007 | 11:35 PM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
I have seen many cars with the inside of the oil cap looking like it has peanut butter on it. Basically its just a mixture of the moisture in the engine and the oil inside the cap area.
I wouldn't worry about a headgasket unless you checked your compression and found big variances in your numbers or you changed your oil and found the peanut butter down there or obvious coolant coming out with your oil.
I would suggest changing out either the seal for the oil cap or the entire cap and oil filler neck once in a while though since they do leak over time.
Old Feb 25, 2007 | 11:37 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
do you blow white smoke out of the exhaust? I think head gasket is blow. Have you overheat recently?
Old Feb 26, 2007 | 05:47 AM
marcelc's Avatar
2002 ML270
What is the consistency of the oil on the dipstick itself? This is all that really counts. I know that not much oil sticks to the dipstick but you can fish enough out for an inspection by repeated inserting and wiping.
If the oil on the dipstick looks like peanut butter then you do have problems, otherwise, IMHO - as written in other posts, you don't.
An emulsion of condensation and oil under the oil cap is normal, particularly if you only travel short distances, it won't affect the oil in the engine or its ability to 'be oily'.
If it worries you, go for a 500 mile trip somewhere as fast as the police will allow, or a blast up some of your lovely American mountain passes, the peanut butter will disappear and your engine will run like a dream.
Old Feb 26, 2007 | 07:06 AM
SUNILP's Avatar
2015 E250D
I would NOT be worried if the underside of the cap looked like peanut butter. It's moisture with oil. Check the oil on the dipstick. The most common cause of that peanut butter stuff is frequent start and stops without letting the engine fully warm up. No big deal.
Old Feb 26, 2007 | 09:17 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Caused by condensation on the oil cap. Normal and a good long high speed drive will cause it to dissappear.
Old Feb 26, 2007 | 09:56 AM
Billiken's Avatar
ML320
sosh & sunman:
Have done a lot of city driving lately. Thanks.
The oil on the stick looks normal. (It's Penzoil.)
No white smoke coming from exhaust.
Heading in for 60k $ervice in mid-March.
I'll have them check oil cap seal.
The truck is 6.5 yrs old.....
Old Feb 27, 2007 | 01:41 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
No worries since the oil on the dipstick looks normal. If its just the cap, as said before, its due to not letting the engine up to operating temps and is condensation. Every so often, take it out for a longer drive so it burns off the condensation.
Old Feb 27, 2007 | 10:21 PM
hanniep's Avatar
01 ML55, 91 Supra Turbo, 05 Audi S4
Does your ML burn coolant on the regular? if not than it's probably condensation under the oil cap, check for white sweet smelling smoke coming out the tail pipes, or excessive coolant usage or jello sludge looking oil on the dipstick. Keep track of your coolant level and if any of the above start to happen get it checked immediately!
Old Feb 28, 2007 | 01:53 AM
AndrewAZ's Avatar
BMW FTW
Common problem(not really a problem)... Go drive your ML on the highway, get on and off a few on ramps at WOT, then check your oil and it will look "normal".
Old May 5, 2012 | 05:36 PM
EricBertol's Avatar
C230 2006
Engine coolant brown, thick and gooey
Last night i noticed some leaking on the garage floor coming from my car C230 2006. I opened the hood and noticed that it looks like its coming from the engine coolant container. This morning i took my car to my mechanic and he told me that my whole engine including the radiator needs to all be replaced. Is this true.? We checked the color of the engine oil and its black, looks like normal color and consistency... What should i do?
Old May 7, 2012 | 10:44 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Eric, you are on the wrong forum. You should be on the W203 forum.
https://mbworld.org/forums/c-class-w203-3
Also you are not explaining this correctly. You found what kind of leak, oil, anti-freeze, transmission fluid? Be specific when you post on the forum
What I believe you mean is that there is some kind of oil in the coolant reservoir and it has overflowed. And what I think the mechanic told you was that the radiator has to be replaced (which is correct) and that the engine has to be flushed out, not replaced.
Old May 14, 2012 | 08:18 PM
HEEMS's Avatar
2002 ml55
this is a common thing. nothing to worry about. it happens mostly during the winter time
