2002 ML Oil Usage Question
Old Feb 26, 2007 | 11:05 AM
pc820's Avatar
Hello,
I was told that my ML would need to have a quart of oil added monthly by MB technicians. This doesn't seem right. Can someone tell me the normal oil usage for this suv? I've never heard anything about a quart of oil every 1,ooo miles.
Old Feb 26, 2007 | 11:30 AM
Billiken's Avatar
ML320
Ouch.
My 2000 ML320 burns/uses no oil...although I just added less than 1/2 quart with just 500 miles to the next oil change.
Old Feb 26, 2007 | 11:50 AM
pc820's Avatar
thanks.. that sounded odd to me. It must be burning oil somewhere.
Old Feb 26, 2007 | 11:54 AM
benzeboy's Avatar
ml320 & c240
Make sure you dont have a leak maybe at your oil filter which will only leak when driving. Are you using the recommended oil? Some oil eveporates more than others. My 2000ml burns maybe 1 qt. or less per oil change. 1 quart per 1000 miles seems plenty.
Old Feb 26, 2007 | 02:03 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
The 02 ML500 that I had never used one drop between changes at the FSS mileage. In fact no MB either V8 or 6Cyl ever required any oil added between changes and since 1998 thats 5 vehicles. Seems you have some sort of a problem either leak or burning oil.
Old Feb 26, 2007 | 02:53 PM
pc820's Avatar
hmm.. puzzling. It doesn't seem to be a new problem as I've searched the boards and this has happened to many other ML owners.
What's my next step? Call MBUSA and complain? My dealer walks the party line and insists it's normal!
Old Feb 26, 2007 | 04:05 PM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
You might want to read this http://www.mercedesshop.com/shopforu...burning+issues
Old Feb 26, 2007 | 05:11 PM
pc820's Avatar
Thanks, sounds like this is an on going issue.
Old Feb 27, 2007 | 03:38 AM
luda's Avatar
ML 320, 1998
Hi.
I just faced the same problem with my wifes "new" 98 ML320 with 75000 on the clock.
When she got the car, I had the engine oil changed with Castrol syntetic, and the maintenance reader reset. (read 9000).
A week ago the low oil level light came on and the reader show 5400 til required change.
Filled 2 liters of oil .
Can not see any oil leakages, no blue smoke, and the car is driven carefully in a mix of town & highway. The engine is also running very smooth and powerful.
Had a similare problem on my 89 300 SE.
When I used syntetic, I always had to add between changes. Are using normal oil now, and have no problems.
As I do not know what kind of oil have been used in the ML before, I am suspecting that the change to syntetic might be a reason for the consumption.
Anybody with the same opinion?
Per.
Old Feb 27, 2007 | 03:35 PM
benzeboy's Avatar
ml320 & c240
Dealer recommend Mobil 1 synthetic. stick with OEM or a good substitute like Amsoil.
Old Feb 28, 2007 | 01:58 AM
AndrewAZ's Avatar
BMW FTW
Anyone know the amount it must use before they cover it under warranty? I thought a while back they had some engine oil class action law suit but I cant recall if it covered the V6 or any ML's past 00. I want to say it was only for the 98 and 98 ML430... but I could be wrong..
Old Mar 1, 2007 | 09:30 AM
pc820's Avatar
check out the link that was posted. I will do the same!
1q every 1,000 miles is ridiculous
Old Mar 2, 2007 | 05:36 PM
jswedberg's Avatar
C32 AMG
About 2600 miles into a 3000-mile trip three years ago, the oil light in our 2000 ML320 went on. I found the nearest service station and had to add a couple of quarts of generic oil (all I could find). This is the first (and last) time that I have ever had to add oil.
When we returned home, I took the vehicle (still under warranty) to the dealership 'just to check things out'. I figured they would tell me that a couple of quarts on a 3000 mile trip was 'within limits'.
They asked to keep it for a few days. They called back after a couple of days and told me MB had authorized a new engine! This was at about 35,000 miles.
The vehicle now has almost 90,000 miles, and i've never added oil. Once a year or so (about 10,000 - 12,000) miles I take it in for the oil change, and that's it.
