00 Ml320 Can't Accelerate
Old Jul 9, 2007 | 09:38 AM
MAML320's Avatar
Unhappy 00 Ml320 Can't Accelerate
Please help!!!!! I’m new in this site. I have a 2000 ML with 92,000 miles my engine light has been on for at least 2 weeks and now when I press gas pedal the car is not accelerate. I really don’t want to go big $ at this time.. I just got my brakes done and my catalytic converters. I took it to the shop they changed all 12 wires and he changed one of the coil but the car still doing the same thing… PLEASE HELP...
Old Jul 9, 2007 | 09:41 AM
MAML320's Avatar
00 Ml 320 Need Help
Old Jul 9, 2007 | 12:09 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Sounds to me like the shop you took it to just threw parts at it. If the check engine light was on why didn't they run the diagnostics with the Star system?? That would give them an immediate answer to what is wrong. Perhaps they are not an authorized MB shop and do not have the Star system. you did not mention if they were or not. You will save money and have a more reliable vehicle in the future if you take it to a dealer for service. It will cost more for the service but its certainly the thing to do for the long haul.
Old Jul 9, 2007 | 02:24 PM
MAML320's Avatar
Thanks for the response .. they did run the diagnostics and he told me i needed to change the wires. after changing the wires i took the car on the hwy after 3 miles the car did the same thing, took it back they told me i needed to change one of the coil they charge me $420 for the wires and $240 for the coil. as a result the car still doing the same thing.
Old Jul 9, 2007 | 05:54 PM
sosh's Avatar
Was this an MB dealer that diagnosed with the STAR system. If not go to one. An independent with a generic reader will get very broad, not precise information and still has to guess. With STAR in the hands of an experienced MB tech the fix will be very clear and easy to correct. I am willing to bet you went to an independent half assed shop. Stop trying to save a nickle and spend for a good diagnosis and repair
Old Jul 9, 2007 | 06:13 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
sounds like ur shop isn't highly trained to pinpoint the problem.
i'd go to other reputable shop, get it fixed and request refund at the other shop...
Old Jul 11, 2007 | 06:05 PM
angeleye328i's Avatar
Have you tried changing spark plugs?
Old Jul 12, 2007 | 04:33 AM
redmansioner's Avatar
The ignition system on your vehicle may not be functioning well.It may have not produced enough amount of voltage, enough to arc cross the gap of your vehicle’s spark plug in order to create a spark that would ignite the air and fuel mixture needed for the internal combustion process to be done by you Mercedes distributor rotor.As the distributor rotor is spinning, the coil sends voltage into the arc across the rotor tip into the contact.It is one of the component to start you car,have it check and it may be the answer to your question.
Old Jul 12, 2007 | 08:21 AM
sosh's Avatar
There is no distributor and no rotor in any current or recent MB vehicles and for that matter most others as well. I suggest that before you give advice that you educate yourself so that false and inaccurate information is not given.
Old Jul 12, 2007 | 09:24 AM
benzeboy's Avatar
ml320 & c240
You did not say if the spark plugs were changed. At 90,000 miles I will consider it. May be a fuel issue?? I agree with Sosh take your car to a reputable mercedes dealer service center.You will save $$ and be less worried in the long run. Good Luck.
Old Aug 2, 2007 | 04:59 PM
MAML320's Avatar
thanks
Guys thanks for all your inputs.. i took the car to the dealer, the issue was the AIR MASS FLOW CENSOR.. once again thank for all your help..
