Ride Height
And also the same for the rear.
Our ML is 20" at the rear and 18" at the front,I am sure that this is not right,
So could someone please confirm one way or the other.
18" - Center of front wheel to bottom fender lip
18.5" - Center of rear wheel to bottom fender lip
Hope this helps. Personally, I do not blame you for your frustration in response... it's amazing that a web site entitled "MBWorld" has an overwhelming majority of converstation in the "Off Topic" (aka: non-Mercedes) column - over 483,000 posts at last count - as opposed to things Mercedes. Whatever. There are better MB-oriented web pages for technical info.
So that means i have either heavy duty springs on the rear or something is un toward,
As the ML is a second user motor, i would imagine that the springs have been changed !,Because it came from a construction company owner,with 20k on it.
It was only because i parked next to another 2000 model that i noticed some differance. and i needed to comfirm which end it was, as theres were 19" all around.
Thank you.
I must argree that the off topic section does get used a lot on here,
but you would have thought that someone besides your self would have replied as well.
But if there is any input, from anyone else, it would be welcomed, after all it's only a matter of going outside with a tape measure,and it would help not only me but anyone else who may have the same problem.
Paul
If you do a search for "ride hight".In other forums there may be help.
I know i found it some where, but i carn't find it at the moment.
Wolfgangs pages are very informative.
http://www.whnet.com/4x4/index.html
(Center of the wheel to the fender lip)
I'll post some photos later.
It's raining so hard over here at the moment in the UK,
As soon as i get a chance i'll post them up.
