New Pads and Rotors?
Old Aug 21, 2007 | 09:02 PM
s.f.clk02's Avatar
CLK320 2002
hey wusup everybody i think i need new pads and rotors i called up a few spots one said they will charge 1100 for everything pads rotors everything
i went on tirerack and saw that they have brembo rotors for 57 each rotor is that a good deal you think i should order those and get pads from the dealership and get them installed at a local mechanic. anybody ever use any other aftermarket pads please help me out.
Old Aug 22, 2007 | 06:26 PM
benz-tech's Avatar
BMW E30. I've turned to the dark side.
use our pads. the pedal feel changes significantly with aftermarket pads. as far as rotors, I will probably put brembos on mine when the time comes, maybe THEY will last more than 20,000 miles. never used them, though.
Old Aug 22, 2007 | 07:32 PM
s.f.clk02's Avatar
CLK320 2002
what are our pads
Old Aug 22, 2007 | 10:46 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
are the brembo rotors from PP drilled?
if not, i'd just get OEM rotors and pads...
just get them from www.oempartsonline.com and have local brake shop do the install...
Old Aug 23, 2007 | 12:21 AM
s.f.clk02's Avatar
CLK320 2002
im not sure what pp means but they are from tire rack this will be the first time ordering rotors.
Old Aug 23, 2007 | 12:32 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
pp = performance products
i've had those brembo rotors b4... they rust quite fast...
i'd get power slot or ate (no experience on this brand)... or OEM...
Old Aug 23, 2007 | 01:04 AM
s.f.clk02's Avatar
CLK320 2002
that oempartsdirect website does not work. any recomendations on brake pads.
Old Aug 23, 2007 | 01:39 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
oops...
it's www.oempartsdirect.com
