How to remove and install rear bumper cover of ML500
Old Sep 17, 2007 | 01:01 AM
Perodogo's Avatar
2002 ML500
Hello everyone. I'm new here and I have a newbie question. Does anyone know how to remove and install a rear bumper cover of a 2002 ML500? I have damage on my bumper and I need to replace it. Any help would be appreciated.
Regards
Old Sep 17, 2007 | 02:12 AM
JM15's Avatar
2002 ML500
Are you talking about where the trailer hitch is or the whole thing?
Old Sep 17, 2007 | 10:47 AM
Perodogo's Avatar
2002 ML500
Hello.
I'm talking about the whole thing. My son backed into a tree and damaged the right side of the bumper beyond repair so I need to put a new cover.
Regards
Old Sep 18, 2007 | 06:41 PM
RALBERT95's Avatar
03 ML350 INSPIRATION
Removal of the rear bumper cover is very easy. Carefully remove the small access panels on the right and left lower bumper cover. Once you remove these covers there are either 2 or 4 bolts inside these covers [ I don't remember...its been quite a while since I removed the cover]. Unscrew these bolts and carefully slide the cover rearward. It should slide right off.
Good luck.
Rich Albert
04 Ml 500
Old Sep 19, 2007 | 11:18 AM
Mike's ML's Avatar
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
There is one bolt behind each small cover and two nuts behind the lower center cover. There may be an antenna cable connected to the right side of the bumper but you don't have to remove that until you get the bumper off. I've had both my 98 and 05 rear bumpers off and it is ridiculously easy.
Mike
Old Sep 19, 2007 | 02:43 PM
Perodogo's Avatar
2002 ML500
Smile
Hello.
Thanks for the replies. I'll try it.
Thanks again
Old Sep 27, 2007 | 12:01 AM
nycloving's Avatar
2014 CLA250 Coupe 4MATIC C117
How about the front cover?
Is the front cover just as easy and does anyone know about the bolt locations (2001 ML 320)?
Old Sep 27, 2007 | 11:46 AM
Mike's ML's Avatar
No, not as easy. I broke all 4 studs on the lower brackets trying to mount fog lights in my 98ML. I had to drill out the old studs and tap for new bolts. I did not notice all the other mounting hardware but it is definately not as easy as the rear bumper.
Mike
Old Sep 28, 2007 | 04:26 PM
nycloving's Avatar
Thanks for the heads-up. Hopefully someone may be able to direct me where to find "how to" info on removing the front bumper on the ML320.
Old Sep 28, 2007 | 06:56 PM
pleubner's Avatar
W163 W164 R230
All that your ML heart desires ......
http://www.pointedthree.com/disc/for...sts=50&start=1
PS: I posted most of the WIS content in PDF format here .....
Just scroll down to the "bumper" section in the WIS sticky thread .... It has all tzpes of bumpers Original, Facelift, AMG (removal and install)
