My 2002 ML500 Jerks and Stalls
Old Dec 17, 2007 | 02:12 AM
Kofi_Boss's Avatar
2002 ML 500
My 2002 ML500 jerks and stalls. Sometimes it comes to a dead stop and I have to sit and wait for an hour before it will restart and move. I changed the fuel pump but the jerking and stalling stoped for about 2 thousand miles. It is doing it again. Can anyone tell me what the problem is?
Also sometimes I have the brake lights and several other lights and a let of beeps go ff but they go away after about 15 minutes and they come back after about a week. Any ideas?
Old Dec 17, 2007 | 02:24 AM
ML430Lorinser's Avatar
1999 Mercedes ML-430 Lorinser Edition
How many miles are on it? I'm guessing you already checked/replaced the fuel filter?
Old Dec 17, 2007 | 10:06 AM
Kofi_Boss's Avatar
2002 ML 500
75 miles and I have replaced the fuel pump and filter. I am being told I need a crank position sensor, could that be the case?
Old Dec 17, 2007 | 12:34 PM
Yup, the crank position sensor is a timing tool for the vehicle. It works with the cam position sensor. We had the same problem that you are having on a vette and chased the problem for a couple days before we realized it was a cam retainer which allowed the camshaft to move from the sensor thus stalling the motor. So to answer the question....yes a false reading/bad sensor will cause it to stall. Is there a check engine light on?
Old Dec 18, 2007 | 11:04 AM
Kofi_Boss's Avatar
2002 ML 500
No there is no check engine light on. I rather have the ABS BAS/ESP/ETS warning lights come on any time the car starts jerking and stalls. Then the brakes start behaving funny and it goes on for a while then it goes away.
Old Dec 22, 2007 | 01:52 PM
The brakes start acting funny because the brake booster is run off of vacuum which is maintained by the engine running. Any updates on your problem? Did you check/clean the MAF sensor?
Old Jan 3, 2008 | 09:49 AM
Kofi_Boss's Avatar
2002 ML 500
I parked the vehicle for the rest of the winter. I will go back to it in the Spring. Thanks for your help.
