I need keys! MB wont sell any more of them
I just bought a used 98 ML320 and it had only one key. I went to the dealer get two more, and they cannot sell any!!! The car has had 8 keys and that is it. It is some hard software limit that was built in years ago into the aml module or something like that. you need a new aml module, and then you need to re-key the entire vehicle. Parts cost from my dealer is $1900, then install...S*().
I will find a way...
Can anyone help me find a savvy Locksmith?
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Sorry but a locksmith can't do anything for you and neither can anyone else. Your only alturnative is to get the new module and re key the vehicle. Actually while it is presenting problems for you it is an excellent security measure. I also do not know how anyone could go thru 8 keys even with a 10 year old vehicle. I would go back to the seller who most likely knew about this. Even MB can't do anything to get you the additional keys. When the vehicle was new in 98 the buyer received 2 standard keys with remotes and a valet key without a remote.
No, think about it, the mechanical sysstem is fine. It is the electronic module that cannot accept more keyid's that has problems. why change all the mechanical parts for no damn reason other than Mercedes computer says this car has that key...
If I could find a way, or if I could convice mercedes to sell me a new module and not force the mechanical re-key, we could cut the cost to an acceptable amount. Think about it. Change the module and the electronics in the keys only...
i know that they sell ml keys on ebay but i don't know if that will work or no. so what's up with the up to 8 keys only for the ml class? is it only for the 98 or up to the new one too?
the MB key system, in recent years, has been consistent in using the security
key system in place now. unfortunately, inherent with this system is the self
limiting number of keycodes which can be used.
http://w210.pietrzyk.net/82bodyelect...ASvehikeys.htm
no (!)....you cannot buy some key off Ebay which had been previously used
for another MB car and to reprogram them for use with your vehicle. the keys
are designed not to be reprogramable.
from Raymond G's link it clearly states that you can have 24 keys total for a vehicle. Only eight can be enabled in one setting at a time though. It seenmns that you only need to switch the system t o use a the next sequence and then you can order up to 8 new keys.
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
Mike
Never EVER buy keys off of ebay. They will not work. They must come through a dealer.
