m class side mirror repair
Old Feb 4, 2003 | 01:01 PM
edzo's Avatar
Hi can someone give me info on how to remove and replace the plastic part that surrounds the driver side mirror?
I cracked the plactic edge backing out of garage .
thanks for any input
Old Feb 6, 2003 | 12:21 AM
Sincity's Avatar
Check ebay. Try typing as a search: ML MIRRORS. I checked today and there is someone selling the outer covers for cheap.
Old Feb 6, 2003 | 02:16 PM
edzo's Avatar
thx for tip but I already got the part, what I am looking for is easest way to install the plastic piece.if u have any input it would be appreciated
Old Feb 6, 2003 | 02:20 PM
jswedberg's Avatar
C32 AMG
I believe the front and back halves snap together.
I fixed mine a year or so ago, then my wife broke the mirror again, and I decided to let the dealer do it, as I was never happy with the job I had done - I could not get the shroud ti stop vibrating at speed.
The dealer fixed it for free, under warranty!
Old Feb 6, 2003 | 03:40 PM
Sincity's Avatar
The easiest way to it is to remove the mirror. To remove mirror, go to inside of door and pop the sail panel trim. Now just unbolt it. Now that you have the mirror in your hands, push the glass around and you should be able to see the mount tabs. Good luck!
Old Feb 11, 2003 | 11:35 AM
edzo's Avatar
thanks for the help!!
