Window switch gremlin arrived!
The renowned electric window switch problem has struck ie window goes down but not up.
Can the front window switch be replaced with one of the back ones, as they look similar to the naked eye and if so how do you get them out?
Thanks for any help.
Also, I've read on hear, do a search, that some pull it apart, sand some contact points down, and it works? never had this issue...I have a 2002...
Mine is a 2000 MlL320 with 128K miles on it...I am just noticing that it is getting harder to roll up and down the driver side window..
Its just a use thing...it is a consumable part that will eventually fail!
TVM
I found it...
https://mbworld.org/forums/m-class-w...t-working.html
I found it...
Forum saved me £100.
Thanks guys.
