Hissing when Accelerating (Driver Side)
Old Jul 28, 2009 | 11:24 AM
pointgrinder's Avatar
2009 E350 Blk w/ AMG Pkg& 2002 ML500 Slvr w/ Sport Package
New problem. I have a 2002 ML500. When accelerating, I noticed a hissing and when I ease the accelerator, the hissing quiets. It seems like its coming out of the dashboard or steering or below by my feet. There is no lack of power and steering seems fine.
Could this be a simple vacuum hose?
Old Jul 31, 2009 | 01:43 AM
Any Responses????
Any Responses????
Old Apr 26, 2011 | 10:31 AM
Hrach's Avatar
2006 ML500
Hello,
I just got a used 2006 ML500 with the same issue. I am thinking it might be a front bearing. Were you able to resolve this issue? If yes please fill me in, or anyone for that matter.
Old Apr 26, 2011 | 11:18 AM
sparks205's Avatar
ml350 2005
i was driving my ml350 last night and hit a big pot hole and thats when my acceleration on the car started to give me issue it would take a few seconds before it response. So i parked the car turned it off and turnn it back on and the check engine light appeared. Now the car will take like 2 seconds to accelerate. Got home woke up this morning still the same issue. is there anything i can do without seeing my expensive mechanic and if not what should he be telling me
Old Apr 26, 2011 | 08:16 PM
Darkmann's Avatar
ML
Originally Posted by Hrach
Hello,
My hissing happened every time I had the A/C on and accelerated (on my E) and was traced to a leak in the climate control system - one of the tubes to the condenser, I believe. Try with the climate control off. If no hissing, you know what the problem is. If it still hisses, let us know.
Old May 17, 2011 | 04:46 PM
rodwilk's Avatar
98 CLK 320 03 ML500 04 SL 500
If its the same problem I had, it was the transfer case. The dealer replaced it. It had the sound of whistling during acceleration. It sounded like it came from underneathe the dash and they even took out the instrument panel. I'm glad it was found because it was driving me crazy. Luckily the vehicle was still under warranty.
Old May 31, 2011 | 09:35 PM
loclark757's Avatar
1988 300E, 1994 E320, 1999 ML 320, 2002 SLK 32 AMG -SOLD-, ML 350SE -REPOSSESED-
Golden rule for your transfer case. Change the fluid and see what happens. Plus its always a good thing to keep it changed frequently.
There's also a great thread on the benzworld.org forum about noises for the W163...
