ML320 heater blows cold air
Old Jan 7, 2010 | 11:33 PM
earaim's Avatar
ML-320
My ML320 2002 W163 has been working great till lately; the heater starts to blow normally (hot) then in few seconds switches to worm then cold "outside air". With the chili mornings these days it’s becoming a problem. I have already replaced the water pump & the thermostat (3 hr job). I read several posts regarding the BLEND AIR ACTUAROR MOTOR located behind the glove box. I also watched the video from youtube on how to replace it. The motor is operating normally and not clicking.
Is there another area I can check before giving up. Any good advise is appreciated.
Old Nov 17, 2011 | 10:26 PM
sdanville's Avatar
ml320
hot cold
Did you fix it ? I have the same problem.
Old Nov 13, 2013 | 10:48 AM
ggiles13's Avatar
ML320
My heater did not stop after working. I started it up one day and the heat didn't work at all; just blew cold air. I turned the temp dial back and forth a couple of times and the hot air came on. Then the next time I adjusted it to cooler air, the heat never came back. Is this a thermostat thing? I changed the fuse as well as the air filter....
Old Nov 13, 2013 | 05:04 PM
art_arev's Avatar
2003 ML55,2007 ML63
Before doing anything major check the temperature control switch in the centre consol
Old Nov 14, 2013 | 01:42 PM
danny4062's Avatar
ML320
Hi, I am new to the forum and desperate for some guidance please. I have a 2002 ML320 and have recently noticed that the heater does not work.
I have changed the aux heater pump which now works, both hoses are the same temp so heat is going through the heat exchanger. The dials appear to work and he actuator motor works behind the glove box. The connecting rods seem to be doing their job...
The engine runs at just over 80 degrees celcius so I am totally lost now. Any help would be greatly appreciated. Thank you in advance. Dan
Old Dec 12, 2013 | 11:41 AM
Zan32's Avatar
Clk 430 conv. + ML320
I have no heat or AC would the temp control switch be my problem too?
Old Dec 12, 2013 | 11:42 AM
Zan32's Avatar
Where is this switch in center consol?
Old Dec 12, 2013 | 06:49 PM
art_arev's Avatar
2003 ML55,2007 ML63
Firstly check the fuse box & make sure your fuse & the relay is working. Find the relay and exchange it with a similar one from the box for diagnostic purposes. If you dont have heat or AC it must be fuse/relay issue. Temperature control knob moght be the culprit if you have hot but no cold or opposite....
Old Dec 12, 2013 | 06:52 PM
art_arev's Avatar
2003 ML55,2007 ML63
Is it only the heater or the AC doesnt work as well? If both dont work check the fuse & the relay.
The dials appear to work? Why do you say that? How would you know they work or not? Because you can turn them??
Old Dec 13, 2013 | 07:07 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You are on the W163 forum and the only vehicle you have listed is a CLK430. If that is the veh. you are asking about, you are on the wrong forum and we can't help you.
If it's a W163 veh. PLEASE UPDATE YOUR PROFILE in USER CP.
Old Dec 13, 2013 | 02:45 PM
art_arev's Avatar
2003 ML55,2007 ML63
Wow...Maj.Dundee, I might have been barking up a wrong tree.....He might have been in the wrong forum
Old Dec 14, 2013 | 11:02 AM
Zan32's Avatar
Yes I have both clk 430 and ml320..
My ac and heat in my ml320 is not working, I checked fuses and relays replace temp control unit and still no AC or heat? Hot wire the compressor 12v to verify that new compressor works but with out wire to compressor No ac or heat control. I've check purple wire under fuse box no 12v.? Please help? Need sys to work..
Old Dec 14, 2013 | 02:41 PM
art_arev's Avatar
2003 ML55,2007 ML63
Zan is your blower switch working? There is the dial switch thats switches on and off the blower. And there is a button to switch on the AC. If the fuse /relay is ok & the blower doesnt come on must be the switch. If the switch is ok then you must scan & clear the codes. If there are AC error codes present the blower will not receive 12v unless the codes are cleared.
Old Dec 14, 2013 | 03:12 PM
Could you PLEASE UPDATE YOUR PROFILE in USER CP, for the second time. The systems changed after 2001.
Old Dec 14, 2013 | 03:21 PM
Zan32's Avatar
[QUOTE="Maj. Dundee;5875266"]Could you PLEASE UPDATE YOUR PROFILE in USER CP, for the second time. The systems changed after 2
Don't know how.. Tried
Old Dec 14, 2013 | 03:49 PM
[QUOTE=Zan32;5875278]
Did you click on the attachment photo in my post? I just did it and it works fine.
Old Dec 14, 2013 | 03:52 PM
Zan32's Avatar
Why is this so important to you?
Old Dec 14, 2013 | 05:16 PM
art_arev's Avatar
2003 ML55,2007 ML63
Different years have different systems of AC/Blowers... Your profile tells as the year and model of your car.
Old Dec 14, 2013 | 06:41 PM
Zan32's Avatar
Yes blower works and dial works too, and yes there are AC error codes, who can I get to clear them?
Thank you this might be my problem.
Old Dec 14, 2013 | 07:41 PM
art_arev's Avatar
2003 ML55,2007 ML63
You havent mentioned the year of your ML in your profile.....I suggest you do that so you can get help from our experts.
Someone with a pro level scanner can clear the codes.
Old Dec 14, 2013 | 08:12 PM
Zan32's Avatar
You havent mentioned the year of your ML in your profile.....I suggest you do that so you can get help from our experts. Someone with a pro level scanner can clear the codes.
2002 ml320. And everyone that I have taken this SUV to did not know about clearing codes...
Thank you again
Old Dec 31, 2013 | 04:05 PM
Zan32's Avatar
Update: I found out there are no error codes curtly on my 2002 ml320. Still no heat or AC . Something else is causing no 12v to climate control mod.
Old Dec 27, 2014 | 10:02 AM
nyduece21's Avatar
2001 ML 320
heat stopped working
I have a 2001 ML 320 and my heat stop but my vehicle is not over heating or anything just no heat. Does anyone knows What could be the problem?
Old Dec 27, 2014 | 10:56 AM
danny4062's Avatar
ML320
You could try removing both inlet and outlet hose from heater matrix licated at bulkhead and using a garden hose, wash out the matrix in the reverse flow to what would be the normal flow of coolant. I had to do this several times before all of the debris cleared. Otherwise, small auxillary pump located near bulk head. These are known to fail but washing out the matrix with a hose wont cost you a penny and is very easy.
