Engine Temperature
Old Jan 15, 2010 | 03:07 PM
ahering's Avatar
2005 E500
Engine Temperature
I have a 2001 ML320 which I have driven for 5 and a half years, for the first about 3 years the engine temperature was stable and always remain just barely above the 80 degrees line, however for the past 2 years the temperature rises without any logical reason to right below the 100 degree line, just about 95/98 degrees. At first I thought it was the A/C, but the only difference I found out was that it was quicker to raise with the A/C on, but even without the A/C turned on, it eventually (way slower) would raise the temperature.
I have asked two different mechanics about this, with the second one I ended up flushing the coolant and replacing the thermostat, but the problem still persists. The mechanic kind of guesses that it may be the clutch of the fan, however he didn't feel comfortable enough to make the statement and have it replaced and he remain clueless. So any idea would be appreciated.
Old Jan 15, 2010 | 04:06 PM
aznxtacy's Avatar
ML500
I have the same problem on my 2002 ML500. Flush the radiator and still have the same problem. Normally, it only happens when driving locally or stop and go traffic, freeway is normal.
Old Jan 17, 2010 | 11:36 AM
ahering's Avatar
2005 E500
Yeah, it follows the same trend, also notice that when temperature is high, oil is burned and have to pour a quarter 2 or 3 times between oil changes. According to the dealer, ha ha, they say we are supposed to add oil every 800 miles, what a joke!
Old Jan 17, 2010 | 06:47 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Try replacing the thermostat, also consider that your radiator even though having been flushed is partially clogged and may require replacement. The fan of course is another possibility. After all its almost 10 years old. Have you double checked the temp gage and sender?? Easy to do with a thermomitor.
Old Feb 2, 2010 | 03:49 PM
EMR2004's Avatar
2011 E63 AMG
Happens to my 2004 ML500 and i only have 56000 miles on it. I think its normal, considering it never goes up more than 100 C. I dont think it burns oil at that temperature.. so i would check some other problem. But, has anyone asked mercedes if this is normal or not?
EDIT: I just checked the Manual. It says, During severe operations or stop and go city traffic conditions, the coolant temperature may rise to approx 248f or 120 C.
The engine should not be operated with the coolant level in the red zone..etc Read it for urselves, so im guessing its normal
PAGE 213
Old Feb 2, 2010 | 03:55 PM
aznxtacy's Avatar
ML500
From what I can see, the ML500 don't have the 2 extra fan in front of the radiator like the ML320 have. The mechanic told me this is one of the downsides of ML500.
Old Feb 2, 2010 | 04:29 PM
EMR2004's Avatar
2011 E63 AMG
The mechanic is stupid, our fans are electronic and not driven by the belt, so theres no clutch
