instrument cluster
Old Apr 3, 2003 | 07:37 PM
Elus2's Avatar
instrument cluster
Does anyone know that a 2000 amg ML-55 instrument cluster can be installed into a 1999 ml430?
Old Apr 4, 2003 | 10:13 PM
C-rod's Avatar
2014 ML350 BlueTec.
Yes..........
it can......but you will need to re-calibrate the speedo....l looked into doing this, but the speedo was to expensive for me....
Old Apr 5, 2003 | 12:02 AM
Elus2's Avatar
Instrument cluster
Re-Calibrate? So this thing has to be done by the dealer? And do u know about the mileage of the replacement cluster can be fixed to match the old one?
Thanks for your informs.
Old Apr 5, 2003 | 11:18 PM
C-rod's Avatar
2014 ML350 BlueTec.
The install.............
is quite easy............To replace the speedo is a ten minute job, the problem is re-setting the new speedo to your present milage, l pretty sure the dealer has to perform this....
Old Apr 6, 2003 | 03:13 AM
Elus2's Avatar
Cluster
So have u actually replace one before, or u know anyone have it done? Well, u know, just don't want to spend that much of money for a cluster and it end up doesn't work.
I did call couple of dealers, the one from house of import said it can't be done, but the one from long beach said yes....
Old Apr 6, 2003 | 08:07 AM
C-rod's Avatar
2014 ML350 BlueTec.
Hey ELUS2
There are a few member's at www.benzworld.org that have replaced thier speedo's to the ML 55 AMG style...l'm sure it can be done......go to that site and ask for Drew...the Benzworld Moderator..he will definetly help you out.......
Old Apr 6, 2003 | 07:03 PM
Elus2's Avatar
Hey c-rod,
talked to Drew, he said it fit physically, but strongly against it due to the electronics problem. So I am now thinking whether I should risk it...Anyway, thanks!
Eugene
