coolant leakage through heater holes in the firewall
- "Did you ever found out what was the problem? and wee you able to fix it? I have a 3 month old baby and I want to makesure the car will be fine when we travel.... Much Thanks in advance!!!
Any coolant that leaks out of the drain tube is excess.
Why are you adding coolant?
If you are filling it above the marked line while the eng. is cold, you are adding too much coolant.
mechanic loosen the screw rings to my radiator hose that's why I was getting leaks!! It wouldn't had been so obvious except he had loosen all 3 hoses on my radiator!
Make the story short it was a simple turn of a screw driver! "Thanks for your help.
I wasn't aware those were the proper levels for the coolant.. All these time I always put about an inch more to the mid level!
- Christian
