tires for 20" rims
Old May 18, 2003 | 04:58 PM
prorcracer87's Avatar
ML320
tires for 20" rims
what kind of tires should i put on 20" rims?? i was hoping to get the same diameter as the stock ones....i have a 99ML320...
Old May 28, 2003 | 01:14 PM
chris's Avatar
2000 ML430
Closest diameter you'll get are with the 295/40/20's
That's what I had on my 20's
Old May 28, 2003 | 03:01 PM
St Nick's Avatar
1998 ML 320
diameter
what are some of the problems that you may have if your diameter with bigger rims don't match the original wheels?
Less\more gas milage?
Less\more odometer count?
etc.
Nick
Old May 29, 2003 | 06:04 PM
ML320
i think the bigger it is...the more gas it uses...so the less mileage your gunna get out of the tank...engine also gets hotter...not hot enough to do any damage though...correct me if im wrong
Old May 30, 2003 | 05:29 PM
ViKTORiOUS's Avatar
W209 - W163
Its not the gas mileage gets bad, its that your MPH will be off a bit due to the diameter of the wheels. Youll also notice a drop in acceleration. Plus your most likely going to hit a pot hole and bend the rim, so try not to get too low profile tires. Dont wanna spend thousands on new rims everytime they bend.
Old May 31, 2003 | 10:24 AM
ML320
how much is the diameter off by with 295/40/20??or even 295/45/20??
Old May 31, 2003 | 11:06 AM
ViKTORiOUS's Avatar
W209 - W163
It shouldnt be by too much... not too sure, never had 20's, ask Chris K.
Old Jun 13, 2003 | 03:53 AM
Ozzie Bob's Avatar
2002 HSV ClubSport R8
Wink
http://www.miata.net/garage/tirecalc.html
Easy way to see the difference bigger/smaller tires will make
Old Jun 13, 2003 | 04:59 PM
St Nick's Avatar
1998 ML 320
Wider wheels
The X5 has 1" wider wheels in the rear. I assume it is for handeling. Has anyone ever tried this on an ML?
example: 8.5" fronts and 9.5" rear?
Nick
Old Jun 13, 2003 | 05:31 PM
Kar don's Avatar
Mercedes-Benz
The 295/45 20 inch tire rides significantly better than the 295/40 dunlop SP9000. The 295/45 i tried were the kumho ecsta STX, very quiet, soft riding tire.
Old Jun 13, 2003 | 07:48 PM
ML320
but it looks like the closest we can get is 295/40/20..with that calculator thingy...when it says your going 60, your going 60.5...so its the closest you can get....
im new to this stuff so i dont know that much
so correct me if im wrong
Cliff
Old Jun 14, 2003 | 02:33 AM
Kar don's Avatar
Mercedes-Benz
Cliff
Here is my 2 cents. If you lower it, get 295/40
If not, get 295/45. I would go this route due to the more comfortable ride. But then again I wouldn't get 20 inch rims to begin with.
