Power Steering Fluid Leak from L Shaped Metal Connector ?
Subscribe
Sep 6, 2012 | 01:13 PM
Hello,
I have a 2004 ML350 and notice a leak from below this metal l-shaped metal connector that the reservoir seems to fit into that is above the power steering pump I suppose. The leak is coming down on to the power steering pump and seems not to be leaking from the power steering reservoir, but the l-shaped connector itself.
It is similar to what this person mentioned:
http://www.benzworld.org/forums/w163...ml#post5410895
"So it looks like i may have a small leak...not at the reservoir o ring, but instead it looks like the leak is coming from the metal "l" shaped thing that comes out of the top of the pump. Looks like the leak is on the top of the pump. How is this possible? Is the l shaped arm just pressed into the top of the pump?"
Any ideas or anyone else encounter this? He goes on to say:
"Got it fixed...it was leaking at the o ring. Took it off and replaced the o ring again. Luckily, my brother had purchased 2 new o rings."
But I am not clear on if it is a DIFFERENT o ring or still the reservoir o ring he is talking about, or if it is something to do with the metal L shaped connector itself? He seems to say that it was the o ring from the reservoir even though he also saw the leak from the l shaped thing itself.
Also, any idea what tools are needed to remove the reservoir? Pliers, flat head screwdriver for c-clip and something for the 1 bolt, yes?
Reply 0
Feb 15, 2014 | 08:27 PM
I have no power steering and am searching to find the Power Steering reservoir. I looked under the hood and found nothing. Any ideas? Thanks
Reply 0
Feb 16, 2014 | 02:44 PM
The reservoir is marked with the red arrow
Reply 0
Feb 17, 2014 | 02:49 PM
Thank you for the download for the reservoir 350ML 2004
Quote: The reservoir is marked with the red arrow
Thank you Art for the download. I will give it a try.
Reply 0
Feb 19, 2014 | 01:40 PM
does anyone know the type of power steering fluid for a 2004 ML350?
I saw on one thread to use Pentosin CHF 11S but on a google search a supplier suggested a "FEBI fluid". Both have to be synthetic. Thanks
Reply 0
Feb 20, 2014 | 01:44 PM
Samson, here you are.....
Check post No5
https://mbworld.org/forums/m-class-w...ease-help.html
Reply 0
Subscribe
Currently Active Users (1)
