2000 ML320 w/193k miles - Fuel Smell
Old Mar 15, 2013 | 09:13 AM
paulzale's Avatar
I searched and didn't find too much, so here goes:
I have over the last month noticed a fuel smell after filling up, which would go away, but the last two fill ups it seems to stay around throughout the whole tank, i.e. full to empty. I am one of those who "over fills" to round off to the nearest dollar.
I am thinking it is the charcoal evaporator canister thing since I do not have a check engine light or fuel on the ground.
I will be changing the fuel filter soon (never have yet!) and am thinking to change the canister, does this sound logical? Any way to be sure that is the problem? Any other thoughts on what it could be?
Old Mar 15, 2013 | 09:19 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You must check for a fuel leak at the top of the fuel pump.
File Type: pdf
Old Mar 15, 2013 | 09:33 AM
paulzale's Avatar
OK, that should be easy to do. I replaced the fuel pump about a year ago due to the fuel gauge not working. I will easily check that when I replace the fuel filter. Any other thoughts?
Old Mar 19, 2013 | 08:55 AM
paulzale's Avatar
I haven't had a chance to trouble shoot this yet or replace anything, still have the fuel smell and just threw a P0442 code last night, any other thoughts on where to start?
Old Mar 20, 2013 | 12:20 AM
I can't understand why you see no urgency in finding the cause/location of this fuel smell. Does "fire" ring a bell?
Old Apr 1, 2013 | 09:42 AM
paulzale's Avatar
OK, no leak seen when looking at the top of the tank through the access panel under the seat.
Would it be one of the following:
- Fuel system regeneration valve
or
- Purge Valve for Fuel Vapor Canister
The smell is near the rear only on the filler side (from what I can tell), I've had the CEL come on for P0442 twice and it has gone off by itself both times after a day or so.
Old Apr 2, 2013 | 04:08 AM
Code P0442, as you know now, is for a detection of a leak in the Evaporative System.
The first thing to do is remove the gas cap and inspect the interior rubber O-ring for cracks and dryness.
If that is not the issue, then there is probably a leak at the Fuel Tank Pressure Sensor (pictured below). The most cost effective way to find out if it is the valve is to have a Smoke Test done at your local mechanic.
Attached Thumbnails 2000 ML320 w/193k miles - Fuel Smell-fuel-tank-pressure-sensor.jpg
File Type: pdf
Old Apr 2, 2013 | 08:25 AM
paulzale's Avatar
My thought is that it is cheaper or the same cost to just throw a new valve at it for $200. I'll check the cap then the Pressure Sensor first.
Old Apr 2, 2013 | 10:05 AM
Well that is strictly up to you.
Old May 8, 2013 | 06:09 PM
paulzale's Avatar
I finally got around to changing the fuel filter and found fuel on top of the pump assembly. I am assuming that the retaining ring is not tightened properly, so I removed and tightened accordingly.
Old Sep 1, 2013 | 07:31 PM
ldalton6's Avatar
1999 ML430
I just had to access the top of the fuel tank on my 99 ml430, not too bad just time consuming to remove all the bolts holding the rear seat, anyway, the top of my canister aslo had about an inch of gas in the top. I dried it off and cranked the engine, there was fuel imediately leaking from the "front line", I took the line loose, cleaned just a little and re-attached it but routing it under the wiring harness, this time, no leak. I had been driving around smelling gas for a few months, it was actually a little scary once i realized that there was almost a cup of gas just sitting under the rear seat. But that was all it was, no more smell, so I assme no more leak. ood luck.
Old Jan 15, 2024 | 04:18 AM
meeloun's Avatar
e300
英文论文代写
拥有多年经验的英文论文代写 http://www.hotessay.net/our_service1.php 专家是你取得成功的关键。这些专家具备丰富的学术背景和优秀的写作技巧,能够根据你的要求和学科领域进行精 准而全面的写作。无论是科学、社会学、人文学科还是商科,他们都能够为你提供高质量的英文论文代写服务。这 些专业的英文论文代写机构不仅能够保证论文的准确性和学术性,还能够确保论文的原创性,避免抄袭和侵权问题 的发生。
