Not enough gas
Old Aug 24, 2003 | 01:21 PM
Chip's Avatar
08 E320 Bluetec
Not enough gas
I run the tank down in my 03 ML500 and it only takes 15 gallons. It's suposed to hold 23 gallons. Is this gas gage issue or is the gas tank smaller than they say it is?
Old Aug 24, 2003 | 07:46 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
my 99 ML430 only takes 15-16 gallons of gas when it's pretty much empty...even though my dealer says it's like 23-24 gallons...
GDawgC220's Avatar
'05 A4 1.8TQM6
oh and btw, they've replaced the fuel sender and level units. still, gas only takes about 15 gallons...that's the same as my 94 c220.
Old Aug 24, 2003 | 08:00 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
1999 has only 20 gallon tank... check your user manual. 2001 or 2002 it was changed to 23 gallons.
My normal fillup on ML430 (MY 2000) was around 16-17 gallons.
-s-
Old Aug 25, 2003 | 11:24 AM
Chip's Avatar
08 E320 Bluetec
The gas tank can't hold 23 gallons then. Why are they lying? I have heard of other brands doing the same thing
This puts the range at 250 to 300. Which isn't much to write home about.
Old Aug 30, 2003 | 03:16 AM
mikepa's Avatar
2003 ML500
I just put 21+ gallons in my 2003 ML500. It's the first time I've ever paid more than $40 for a fill up since I was in England.
Old Aug 31, 2003 | 09:59 PM
Popeye430's Avatar
ML 430
I have a 99 ML 430 and my fillup is around 15-16 gallons. I thought the ML 55 was the only one with the 23 gallon tank.
Old Sep 1, 2003 | 05:38 PM
Steve777's Avatar
ML350
Inaccurate Fuel Gauge
All the ML (or most of them) fuel gauges are inaccurate. I have reported this several time to my local MB dealer and even had a factory rep come down and check it out. MBUSA knows about this but will not fix it. They issued some sort of internal tracking number to identify this problem, but the dealer keeps telling me that MBUSA does not have a fix for this problem. The lucky thing is that at least it shows less gas than actually is in the tank, so you will not run out of gas. I have had 4 sending units (fuel pump combination) replaced and have had 4 fuel gauges and 2 complete gauge clusters replaced but the problem persists. I now have a letter into MBUSA legal to get this resolved. I doubt anything will come of it though.
Old Sep 1, 2003 | 06:10 PM
mikepa's Avatar
2003 ML500
When does the lemon law come into play - or isn't a broken gas gauge serious enough?
Old Sep 1, 2003 | 07:46 PM
Chip's Avatar
08 E320 Bluetec
Well wheather the tank is smaller than they say it is or this is a design flaw that MB isn't going to waste time or money on a Jeep Wrangler can go farther on a tank of gas.
