Chirping front end and rattling
Old May 6, 2013 | 07:53 PM
pcarrino's Avatar
mercedes 2003 ml350
My 2003 ML350 has a chirping sound when you first accelerate. Then a constant rattling. I replaced both front bearings and the left side front cv shaft. I think it could be the front drive shaft. There seems to be some play at the rear joint. Is the normal or could that be my problem? I am not sure that it could be the front diifferential. It seems to drive fine except for the noise. Reading the forum I see chirping could be the drive shaft. And ideas? Help please. I guess replacing the universal joint is cheaper than the differential.
Old May 26, 2013 | 12:40 PM
TuanNguyen's Avatar
2003 ML350
Same problem here... Help...
