New to forum W163 and has few questions.
Old May 19, 2013 | 03:06 PM
AsianR350's Avatar
08 R350, 12 Mercedes R350
Hi all,
My 16 years old son just got 2002 ML500 and I have few questions to ask for help.
1) Fuel gauge showed empty even some gas still in the tank. He has filled up the tank, the low empty light went off but the needle still show empty.
He filled up the gas tank every 250 miles base on the mileage on the cluster instrument. I believe that the fuel sender which built in the fuel pump failed that need to be replaced as the whole unit.
How much the total cost to replace the fuel pump at the MB dealer vs Indy shop?
2) There is a message service maintainance showed :" the symbol wrench -730 d".
What kind of service does it need?
Thanks in advance.
Attached Thumbnails New to forum W163 and has few questions.-img_0874-1-.jpg
Old May 19, 2013 | 10:50 PM
AsianR350's Avatar
Found the owner's manual.
For question no. 2: It is B Service and past dues over 730 days. Huh! last owner never reset the service reminder.
Old May 24, 2013 | 07:46 PM
AsianR350's Avatar
I pulled out the fuse#5 while the key is in ignition pos.#2 and put the fuse back. All suddenly the fuel gauge shows full now. I will wait to see when the next fuel filling up if the problem goes away.
Old May 25, 2013 | 03:49 PM
quietdiamond's Avatar
ML320
Is there a trick simular to this to get the check engine light to turn off? MIne turned on because the coolant ran low, and now I can't get the light off.
Old May 25, 2013 | 04:39 PM
AsianR350's Avatar
Working Fuel Guage after pulling fuse#5 and few pics. of 02 Ml500
Fuel Gauge shows full now.(driven 55 miles and still work)
Attached Thumbnails New to forum W163 and has few questions.-fuelgauge.jpg   New to forum W163 and has few questions.-02ml500.jpg   New to forum W163 and has few questions.-2002ml500.jpg
Old Dec 30, 2015 | 11:22 PM
Okoi Owunka's Avatar
ML500 2006
Please where is the position of the #5 fuse for fuel guage
Old Dec 31, 2015 | 04:29 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You are on the wrong forum.
https://mbworld.org/forums/m-class-w164-72/
