truck lid tail light replacement
Old May 29, 2013 | 10:01 AM
angelo c's Avatar
ml 430
any tips on replacing truck lid brake lights on a W 163(2001 ml 430). got pulled over by a po po the other night said my lid lights were out. never did them before.
thanks.
newbie post.
Old May 29, 2013 | 07:04 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
First check to see that fuse #15 is not blown.
If not here are the instructions for bulb replacement.
You could also have a problem with the brake light switch.
File Type: pdf
Old May 30, 2013 | 09:13 AM
angelo c's Avatar
ml 430
Tail lights are functional. its the brake light in the tailgate that's out.
thanks for the diag though. one for the tailgate would be awesome
Angelo
Old May 30, 2013 | 09:29 AM
Have you removed the cover to see if the bulb is blown?
Old May 30, 2013 | 09:41 AM
angelo c's Avatar
ml 430
will do in a few hours. ill report back.
thanks.
Old May 30, 2013 | 09:49 AM
If it is blown, the bulb # is 7506.
Old May 30, 2013 | 11:09 AM
angelo c's Avatar
ml 430
bulb is out. we'll start there.
thanks
