ML350 Washer reservoir bottle leaking
Old Sep 7, 2013 | 08:31 PM
dutchymeakin's Avatar
ml350 2003
okay you geniuses.....how the hell do I get the bottle out of the engine bay???
I have disconnected everything and the darned thing is ready to pull out however no room to get it out??? what is the trick - removal of the pollution box and fuse board or front radiator support panel?. Obviously have to repair the leak but simply cannot get the water bottle out!! HELP!!
Old Sep 7, 2013 | 10:31 PM
CLLARK1's Avatar
01 ML430 86 190D
I own an 01 ML430.After removing bolts there are two rubber grommets on the bottom of reservoir.You have to pull up on reservoir in order to lift it out of grommets.I have read MB installed a 7.5 liter reservoir on some models,I am not sure how to remove the larger reservoir.
Old Sep 7, 2013 | 10:36 PM
ml350 2003
ml 350 reservoir bottle
It would seem that the fuse box has to be removed. whilst looking for a replacement on ebay, a listed item replacement advises removal of the fuse box. Guess this one goes to the panel shop, getting to involved now. The bottle is (it seems) worn through on the bottom. Not leaking from fittings but actually from the container floor. thanks guys.
Old Sep 9, 2013 | 07:07 PM
CGL1's Avatar
'05 ML350 SE
- Remove upper frame cross member
- Disconnect connectors and hoses from pumps
- Unscrew bolt
- Remove Fuse Box cover
- Loosen reservoir from the rubber grommets by pushing the reservoir inwards (towards engine), then upwards. You may need a helper to slight lift the radiator.
