ml 2.7 163 automatic stuck in first gear
Old Sep 9, 2013 | 06:55 AM
chrisadams's Avatar
ml 2.7 automatic 2003
I have a 2003 ml 2.7 diesel automatic which is stuck in first gear.Will start ok and drive but no gear change .Also once in drive cannot put into reverse without first turning engine off.Does anyone have any idea what the problem may be and any possible solutions?
The ESP ETS and BAS are also now on
Have replaced brake light as per other threads but this has achieved nothing.Any suggestions???
Old Sep 11, 2013 | 04:02 AM
DrX's Avatar
DrX
2002 ML320, 2003 A160
You are in "limp-home mode", which is usually 2nd gear. Hence the thunk you feel when you shift it out of neutral. There are many possible causes.
You need the codes read to determine the fault, then cleared in order to get out of limp mode. If you can't access a code reader, drive in 2nd gear to your nearest dealer or indie mechanic. Or hire a tow truck.
Old Sep 13, 2013 | 03:48 AM
DrX's Avatar
DrX
Originally Posted by chrisadams
The fault code is P1856 and says something like selection lever detection has failed .Anyone know solution?
I am awaiting the guy who did diagnostic to come back as he did not seem to know what needed doing
What are your thoughts on the matter?
If the fault code indicates "selection lever detection has failed", then you'll need to start looking for causes. Corrosion of the connector at the gear shift lever module, maybe liquid in the module itself. Have you ever spilt coffee into it, or left the sunroof open when it rained?
Perhaps a previous owner did one of those. How long have you had it?
