Aerial and camera
Old Sep 14, 2013 | 05:12 AM
tedcaton's Avatar
1999 ML320
Aerial and camera
Hi
Can some one please tell me where the aerial is?
Has any one got any ideas how to run cables from back trunk to front for a rear camera?
1999 ML320 based in UK
Regards
TeddyC
Old Sep 14, 2013 | 01:15 PM
Mike's ML's Avatar
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
The antenna is the rear window defroster wiring in the glass.
Mike
Old Sep 15, 2013 | 02:48 AM
tedcaton's Avatar
1999 ML320
thanks
Hi Mike
Thanks for that as I am having trouble with radio reception and I need to start somewhere
The reason I need to know if there is a easy way to run cable from boot to front is I would like to install a rear reversing camera.
I have only owned the car for about 4 weeks and its my 1st Mercedes
thanks again
TeddyC
Old Sep 18, 2013 | 05:48 PM
CGL1's Avatar
'05 ML350 SE
Camera.
I routed mine through an opening at one of the license plate lights, then along one of the sides of liftgate, into headliner (I left some slack for when opening and closing liftgate) and along the top sides from rear pillar (C pillar) all the way to front pillar (A pillar), then down and into dash and to back of stereo unit. Will dig up some pictures if you need.
Old Sep 18, 2013 | 06:53 PM
tedcaton's Avatar
1999 ML320
hi
Hi thanks for that but I have had a look at the head lining and it looks quite tight to roof.
If you have got any photos would be much appreciated
regards
TeddyC
Old Sep 18, 2013 | 08:50 PM
CGL1's Avatar
'05 ML350 SE
Take a look at these pictures. Once I got the wire into the headliner, I ran it diagonally across to the side. From there on, it's just a matter of simply tugging/hiding the wire.
Old Sep 19, 2013 | 02:56 AM
tedcaton's Avatar
1999 ML320
Hi Thanks for the photos very helpful
will have a go with that in the next week.
Also loved the LED lighting looks great.
Regards
TeddyC
Old Sep 19, 2013 | 06:03 PM
CGL1's Avatar
'05 ML350 SE
No problem and thank you.
Old Sep 20, 2013 | 03:56 AM
DrX's Avatar
DrX
2002 ML320, 2003 A160
Originally Posted by CGL1
I routed mine through an opening at one of the license plate lights, then along one of the sides of liftgate, into headliner (I left some slack for when opening and closing liftgate) ...
You can fully conceal this wire by running it under the liftgate trim panel and through one of the rubber tubes that conducts the wires to the licence plate lamps/tailgate lock actuator/rear wiper/defroster.
A loose wire hanging between your tailgate and roof looks untidy.
Old Sep 20, 2013 | 07:31 PM
CGL1's Avatar
'05 ML350 SE
That is correct. Tried that and gave up.
