reading error cd
Old Nov 3, 2013 | 10:14 AM
napstera's Avatar
ml270
Question the cd don't play my burned cd music, when put the disc says error
hello, i burn some music also tryed like data cd, audo cd, and mp3 cd but again can't play it says reading error , or inserted cd and nothing.. how need to be burned to play the music? the cms is 'command 163'
Old Nov 4, 2013 | 02:49 AM
DrX's Avatar
DrX
2002 ML320, 2003 A160
No idea, but when you have success please post your technique. I would like to stop supporting the music industry with my hard-earned dollars.
Old Nov 4, 2013 | 04:43 AM
napstera's Avatar
ml270
hm you mean can be played only original? ;(
Old Nov 4, 2013 | 07:34 PM
DrX's Avatar
DrX
Not necessarily. Read this: http://www.wikihow.com/Burn-Music-to-an-Audio-CD
The directory structure and file types of your burnt CD must match those of an original factory-made one.
Old Nov 25, 2013 | 08:57 AM
napstera's Avatar
ml270
what write method need to use? because i fail whit many cd and again reading error? what is better 'disc at session' or 'track at once'? i was succses whit one of cd maybe its from cd disc brand problem or?
Old Nov 28, 2013 | 04:14 PM
DrX's Avatar
DrX
If you can't remember how you made the 1 successful CD, then use an old-fashioned pencil-and-paper method to write down which method you're using each time.
Consistent results appear beyond your capabilities at present, so you'd be better off spending the money on original CDs instead of making coasters.
Old Nov 29, 2013 | 07:11 AM
napstera's Avatar
ml270
i find the problem its about disc brand, some are not reading other are, its not from write method
Old Nov 29, 2013 | 08:13 AM
psnevets's Avatar
2017 W166 GLE350, 2005 W163 ML350 Special Edition
What brand works well and what does not?
Please educate us. Thanks.
Old Nov 30, 2013 | 12:01 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
a
Old Dec 2, 2013 | 04:29 PM
art_arev's Avatar
2003 ML55,2007 ML63
Make sure the audio cd format is WAV. Any other format a CD player(benz) in your car will not recognise. If you are copying originals at least use software that disables write protection. DrX send you a link read it.
Your other option is change to a aftermarket head so you can play mp3's
