Windshield water reservoir indicator on/off
Old Jan 7, 2004 | 03:17 AM
dfulgo's Avatar
2020 - G63; RR.AB; ML350; ML320; ML400; M3; 200CE; 200E
It started two weeks ago, with the tank 3/4 full, it randomly turns on and, after awhile, it goes off.
I checked the wiring to/from the tank and everything seems correct.
I filled up the tank (just in case), and, obviously it didn't help.
Since I heard that the sensor seems to be very finicky, particularly with MB washer fluid, I'm wondering if adding simple water can be a solution. Till now I've added 1 liter and the problem still there...
...thanks a lot in advance and, BTW, happy new Year...
Old Jan 7, 2004 | 12:07 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
probably the sensor is messed up. what year? if u'r under warranty, take it in and they'll prolly replace it.
-G-
Your right tho, u do have it worse, lol.
Old Jan 7, 2004 | 12:17 PM
dfulgo's Avatar
Originally posted by GDawgC220
.... what year? ...
...ooops, I forgot, ...anyway now is in the signature... MY 2002
Sooner or later I'll be forced to go to the Dealer but..., you know, it's a so "stupid" thing...
Old Jan 7, 2004 | 12:46 PM
Harder's Avatar
BMW 320i
Hello,
I feel your pain! I have a 2002 ML and I went through 2 washer reservoir fill sensors before I decided to disable the sensor. A flashing Yellow light can be a real pain.
Steven---
Old Jan 7, 2004 | 12:49 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
Yup.
-G-
Old Jan 8, 2004 | 12:31 PM
dfulgo's Avatar
Lightbulb
...well, ...I know it's a boring thread...
...but i keep posting just for future reference
Anyway, after I added the "clean" water, the sensor kept showing up once in awhile for the next 24 hours and NOW it's OFF since 48 hours , of course I'm crossing all my fingers BUT, some questions are arising:
1) It can be something "TEMPERATURE-RELATED", since here there was 0°C., which now are (in the last famous 48 hours) +3°C.; it would be interesting to know whether the "bottle warming system" has an activating outside temperature range or not.
2) Same as above but, now, considering the chemical composition of the fluid (X% water + Y% soap) = Different reactions at given different temperatures.
3) (X% water + Y% soap) = Different SENSOR reactions.
It would be very interesting if a GURU (ML GOD & Co.) would Confirm/Deny these possibilities maybe by telling IF the gold-like MB Washer Fluid is an already mixtured product or if it's a Dealer-made composition.
...wow..., pretty long eh? ...sorry...
Old Jan 9, 2004 | 11:22 PM
GamblerZ's Avatar
Mercedes Benz ML500
I believe that there was a problem with the ML reservoir design. You might want to check to see if there is a TSB.
Old Jan 11, 2004 | 06:31 AM
S55inPA's Avatar
Fiscal Neo Con Express
hey guys,
the same thing happened to me this past week.
i think it might be tempature related.
i live in the northeastern USA and it has been
very very cold here...-10f at night.
i left my ML500 at the airport lot for 5 days.
when i started it up the lignt came on.
after i came home and parked in my garage
the light has since gone out and hasn't come
back on since.
Old Feb 11, 2004 | 02:52 AM
dfulgo's Avatar
Thumbs up PROBLEM SOLVED !!!
...yeah guys: as per my "suspect", the sensor don't like too much the water..., after many attempts by adding simple water, I started to add simple soap... "et voilà"...
- no need to replace anything
- no need to go to the dealer
...just for future reference...
Old Feb 11, 2004 | 07:51 PM
S55inPA's Avatar
hey guys,
after checking and refilling my reservoir the light had come
on again about a week later. so i grabbed another gallon
of windshield wash. poured it in and then checked it in the morning. seems the reservoir was cracked so i have since had
it replaced under warranty. my dealer had it in stock. i guess
they are problematic.
also....the dealer replaced at no costs to me the front brake
pads. i had 22000 miles on them and they had begun
squealing really loud with the recent cold weather. since the
change no noise at all. i can't say enough good things about
my dealers service department. the guys there treat me great.
two thumgs up
Old Mar 15, 2013 | 05:00 PM
2002ml500's Avatar
GL450
Washer light
Same issue here. I suspected temperature as well. Park it in the garage overnight and no issue. Leave it out, and the light is on...
Old Mar 15, 2013 | 05:01 PM
2002ml500's Avatar
GL450
How did you disable the sensor? I'd like to do this too...
Old Mar 16, 2013 | 03:31 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Remove the electrical connector.
File Type: pdf
Old Mar 16, 2013 | 11:43 AM
2002ml500's Avatar
GL450
Stays on even after disconnecting. Reconnected, tapped on it a little, light went out....
