Checking oil level via instrument cluster
Old Jan 19, 2004 | 08:23 AM
JAD's Avatar
JAD
I have a U.S. '99 ML430. When I check the oil level via the instrument cluster, the results display in metric litres instead of the U.S. measure of quarts. What gives and can I fix this? Thanks.
JD
Old Jan 19, 2004 | 11:38 AM
Stiggs's Avatar
2003 CLK55
I hate to sound stupid, but...I didn't know you could check the oil from the instrument cluster.....so how do you do that??
Old Jan 19, 2004 | 12:48 PM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
I believe its in the owners manual. I prefer to do it the old fashioned way with the dip stick though.
Old Jan 19, 2004 | 06:28 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
none of the ML's I know have the MFD (multi-function display), so you can't check the oil VIA the instrument cluster...only way is the old fashion way of lookin' under the hood and pull that dipstick out
-G-
Old Jan 19, 2004 | 08:17 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
GDawg C220, you are 100 percent wrong. This has been on the ML's since the beginning. With the engine off, turn the key to position 2, wait till the odometer display shows all dashes then hit the odometer set knob and the display will read the oil level
Old Jan 19, 2004 | 08:19 PM
f4i 954's Avatar
2009 e class 2012 ml350
Yes you can.
Turn ignition on, wait until the display turns into --------------- & hit reset twice.
Old Jan 19, 2004 | 08:25 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
well damn. Guess ya do learn something new everyday
thanks for the tip.
-G-
Old Jan 19, 2004 | 09:58 PM
Sincity's Avatar
Geez...had the ML for 4.5 years and I didn't know that!
Old Jan 21, 2004 | 01:08 PM
Stiggs's Avatar
2003 CLK55
lets see......to answer the original question.
480ml = 1 pint
2 pints = 1 quart
4 quarts = gallon
1000ml = 1 liter
I knew all that conversion crap in drug school would pay off!!!
