drip coolant when too cold outside?
alright, when the ML sits outside for a day or two in really cold weather (0-10 degree's), it drips about 3-4 drops of coolant onto the engine block. It drips directly in the upper right corner, right below the tubes from the coolant housing.
is this normal? I've never seen it on other cars where it does that? Maybe the tube is not as flexible and it lets some seep out? Debating whether to take this to get it checked out or wait till service time...
-G-
I'm new here and would like to respond to this email regarding the coolant leak. My ML has been in the shop so many times I have a cot with a soft pillow waiting for me at the dealer. But anyway the problem with the leaking is not the clamp it is the hose. I had my lower hose replaced and the leak was gone. 1 week later no leak and all is good until 2 days ago I noticed a coolant leak on the other side
It happens to be that the upper hose is now leaking. I was just at the dealer yesterday for them to inspect the leak. The placed a new upper hose on order.
I checked the clamps myself and found them to be tight. My service rep told me that there is a issues with the hoses when it is extremely cold, causing it to leak. Talk to your service rep and find out about the hoses.
Connect the tester to the coolant reservior tank after you remove the radiator cap and pump up the pressure to 12 psi. Then start looking for leaks.
ONLY do this test when the coolant is cold, ie the engine has not been run for a good while. The reason being that the seals and hoses expand with heat and prevent the leak from either occurring or from being spotted easily. With the system cold the pressure applied to the system will more easily show you where your system is leaking.
