99 ML430 starting problem
Old Jun 10, 2016 | 05:43 PM
chopperpilot's Avatar
2007 Mercedes ML350, 1999 ML430
I have a 99 ML I'm having a problem with. When I go to start it, it will run through the start cycle (turning over) but will not start. I will turn the key back to off and start it again and it will then start and run. This happens almost every time I start it. It sometimes starts a little "hard" on the second try but it always starts. If I shut it off for a minute or two, it will usually start on the first try. Any ideas? Thanks!
Old Jun 11, 2016 | 04:53 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
It appear to be a fuel delivery problem.
Working with a cold engine, turn the key to pos. #2 and leave it there for 15 sec. and then turn the key to start.
If it does start, then the problem is the fuel filter or the fuel pump, or both.
Old Jun 12, 2016 | 11:29 AM
Thanks, Maj. I tried that to no avail. We'll do the fuel pump.
Old Jun 12, 2016 | 08:23 PM
Did the eng. start after the 15 sec. wait?
Old Jun 12, 2016 | 10:34 PM
No, it didn't. It did the same thing it usually does: I restart it and it starts up.
Old Jun 13, 2016 | 07:02 AM
Before you buy anything, why don't you check the fuel pressure with a fuel pressure gauge?
File Type: pdf
Old Jun 13, 2016 | 11:10 AM
I'll try that. I need to find a fuel pressure gauge. Thanks!
Old Jun 14, 2016 | 03:16 AM
Amazon.
