NEW OWNER 2001 ML320 Questions???
1. My ML came with the MCS LCD and CD changer in the rear but no Navi CD player behind the LCD. How many pesos will it cost me to get that installed...? Can you use the Navi CD's in the rear changer?
2. When I turn on my ML the MCS screen turns on and gives a message "Telaide Please Visit Workshop"...? I think that means visit the dealer..??
3. The Flexible Service System number that is displayed in the same location as the odometer and trip displayed like this.... (One or Two Wrenches) then a DASH and then 6700. Does that mean the system is indicating 6700 miles to service or its past due 6700 miles for service and the dash actually stands for a minus?!!
4. Also the vehicle didn't come with a second key fob or manual... Luckly CarMax will reimburse me for those. Just curious how much they both go for...?
Thanks for any help.
Baltimore Tom
1. You can't use the Nav CD's in the rear changer. The Nav CD player behind the LCD was a $2000.00 option in 2000 models. You might want to call the dealer for prices for unit and installation. If your handy you might find one on ebay and install it yourself.
2. Don't know about this question.
3. One wrench indicates 'A' service, two 'B' service. Sounds like your 6700 miles past due on you service. Having never been over due on my service myself thats a guess on my part.
4. Key fobs are expensive and only upon proof that your the owner will you be able to buy only at the dealership. I believe they are a little over $100.00 or so. You can buy an owners manual by calling the 1-800-FOR-MERCEDES.
A lot of good information can be gotten here on the internet about your truck. You also might want to check out the forums at http://www.mercedesshop.com/shopforum/index.php3
Good luck with your new truck.
What is "A" service and "B" service...??
Sounds like the service computer wasn't reset when it was at the third party dealer. I will probably take her in and get all my i dotted and t's crossed.
tom
The owners manual explains in detail what the "A" and "B" services include. Both include oil and filter changes along with inspecting a few things.
Flexible Service System - A-Service
What we do:
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
Flexible Service System - B-Service
What we do:
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect front axle ball joints and Poly-V-belt
As of 2003, the CD-Nav module was replaced by a DVD-based nav module. The benefit is that instead of having separate CD's for each region, one DVD fits all of the United States and Canada - so no longer any need to get more than one disk or switch disks on-the-go.
The DVD module can be retrofitted to an older (2000 and up) ML - installation should be the same as with the CD Nav module.
The nav system needs the CD/DVD to be in the front slot - won't work in the changer in the back.
The TeleAid workshop message means it wants to go to the dealer. And the -6700 means that it's 6700 miles past due. Check the records to see when the car was serviced and if/when the A and B services were done.
Hope this helps
