04 ML350 squealing on acceleration
The squealing started after I replaced the pads and rotors but I am not convinced that this is the cause since it only happens while accelerating. The only reason I replaced the pads and rotors is due to 1 warped rotor that was pulsing while breaking. I am the type of vehicle owner that will replace all 4 even though only 1 is bad.
I am meticulous about maintenance on my vehicles.
It is never taken off road, never used to haul heavy stuff, never driven hard.
I cant think of any more details off the top of my head. I tried using the search and could not find anything that was remotely close to the issue I am having. Thank you in advance.
04 ml350
143k miles
new pads and rotors all the way around (meyle)
new belt (gates)
new idler pulley (oem)
new tensioner pulley (oem)
fresh gear oil in front and rear (royal purple)
fresh transfer case fluid (royal purple)
fresh oil change (Mobil one)
Giovanna wheels (much lighter than stock wheels)
You must clean the areas on the caliper with a rigid wire brush where the brake pads fit into (red arrows).
After cleaning, apply a small amount of Copper Based Anti-Seize paste to those areas on the caliper.
Took everything apart and cleaned it with a wire brush and applied copper anti seize. It is still squealing.
Any other ideas?
One of the things that happens only when you accelerate is the torque of the engine makes it rotate clockwise on its mounts. If the LH mount fails (which is subject to the most tension - the RH mount gets compressed), the left front corner of the engine will sit up. This could cause rubbing by a component that rotates at a constant speed compared to engine RPM or wheels. Like anything driven by the serp belt, including the fan, alternator or AC compressor.
