Need help with AC, 1998 ml320
So, got my ml used with 320 000 km on it, and, everything was working great. Ac did work perfect. Last week, hot weather 80 f, and ac was making weird noise like it was getting on and off on a 3 4 second cycle, i was driving so could not chek it......after a while, no more ac ( and no more cycling noise ) . here are the facts : all fuses ok, pressure in low port ok ( cheked with gage ), light on the ac button goes on when pushed. But, compressor does not come on, the clutch part of the pulley does not spin !
Any ideas??????
I would like to try and repair it without changing the entire clutch/compressor assembly and loosing all freon......
Thanks a lot guys !
A specialist is something i can not afford to pay, and also dont want to, paying a specialist to fix a 1000 dollar beater would be to mutch i'll just leave it like that !
The pressure you are referring to is static pressure which means that some refrigerant is present, but not the amount required. Please read.
http://aircondition.com/tech/questio...ith-Gauges-FAQ
