I'm sure this has been asked about a thousand times but... I have a 2001 ML320. It came with the MCS and CD changer in the rear. But no "in-dash" unit behind the MCS screen. So I found the unit for 350 bucks..!!!! at Clair Parts... but was curious about the install..?? Do I need any GPS signal setup from a dealer, or is that just the newer DVD system. It seems like it could be a simple snap in jobber...?
Also is there a notorious oil leak thing with the ML's that I'm not aware of... I'm pretty sure I have a small oil leak.
Thanks for the help.
It should be a snap-in for an '01 ML. Dealer reprogramming is required for '02-onwards.
thanks akshi.... appreaciate it.
Quote:
You're welcome.Originally posted by tkelley
LoL - never thought about someone seeing the 'mb' in my name as being Mercedes-Benz
m is my middle initial, and bakshi is my last name
Send me an e-mail address that can handle a large file size and I will send it to you. It's pretty easy but you need an antenna splitter and two special antenna cables that all go under the front passenger seat for a NAV install ... you didn't state if this was just a CD player or a CD Nav ... anyway the bulletin is for both.
If you e-mail me directly be sure to state what the e-mail is about.
Paul:p
Paul:p
Paul,
If it's not too much trouble, could I get a copy of that bulletin also?
TLo
TLo
I just added the CD/NAV install bulletin to my website. Go to the Miscellaneous Info page and you will see it there.
The site is located at:
Paul's MB Info Website
Paul:p
Paul:p
Explore
