trunk not locking
when I press the lock button to lock the car, it locks all doors except for the trunk...
you can open it but the alarm will go off, so I guess it thinks it's acutally locked but not? Could it be the actuator that controls the lock for the trunk?
thanks!
sorry...mine was warranteed.
I hope it's just the lock sticking but it doesn't look like it
The actuator is about $90...and expect $250 in labor...they have rip the door trim to get to it...
Good luck..
BUT, some good news hopefully. I crawled into the trunk and shut the door behind me so I could see what was going on :p
the actuator is actually working, I just don't think it's catching the lock. If I manually lock it from the inside and unlock the car with the remote (using either unlock button twice or trunk unlock button) it will unlock the trunk. It just won't lock it. I can feel the actuator working, it seems like it's slipping when trying to catch it into the lock position...so maybe the whole thing doesn't need replacing, possibly just something came loose?
GDawg, youre right its just not catching if the actuator is working. its a DIY job. pull the trunk end apart and youll see it, pretty obvious.
thanks man, you've been a great help
is it hard? I'm thinking of taking the door panel apart and taking a look...something easily that can be screwed up?
no problem, thats what a forum is for, right? to help each other out. (except the few that come here to **** and moan about how they hate the ml...then why are they even here?)
any danger of snapping those clips?
had the same problem. i took the panel off and looked at the lock inside. theres a pin in there that holds the pull that u can open from the inside. the pin slide out of place. i put the pin back in place and put some grease on it n its fine now.
i haven't had time to try yet, I think I will this weekend when I'm free, thanks for the help man.
I'll probably have more questions when I'm doing it, haha, maybe I'll bring my laptop and use my wireless to post questions while working ^_^
