w163 Blend door motor calibration ???
What knob are you referring to?
Because you were supposed to completely remove the upper section skin to avoid any damage.
https://www.youtube.com/watch?v=-iOAhZ1zRpw
when i installed if i eather had to have all the way to cool, or all the way to hot or in the middle.
As long as the car was not running, the position of the temp. dial has nothing to do with your problem. But the condition of the white lever does. Was it installed correctly to the motor and was it not broken.
You might have to look at the motor again.
Only the levers matter.
If there is nothing wrong with the installation, I would get a used Denso A/C Controller from ebay
Remove both covers under the I.P. Under the left side of the console the controller is held in place by one screw. Remove the controller from the right side. After installing it,first test it without reinstalling everything
BTW, i noticed that my windshield gets really foggy if i dont run A/C, maybe that is a symptom of something? Thank you mr Dundee for all ur help!!! hope you not tired of me yet.
