Remote Starter Install
Old Jun 17, 2004 | 09:07 PM
ML320 Man's Avatar
ML320
Had a technician friend of mine install a Viper 791xv alarm with a remote starter kit. Got the alarm installed but couldnt get the remote starter to work due to the transponder security of the ML320. We tried installing a universal transponder kit that uses a spare key but it wouldnt work unless you had the key in the ignition. Has anyone had the same problem and came up with a working solution?
Old Jun 18, 2004 | 01:35 AM
pointman's Avatar
a car that can't do the throttle reset.
mine works fine...what EXACTLY is the issue with the install...ill ask my installer.
Old Jun 18, 2004 | 07:44 PM
ML320 Man's Avatar
ML320
We used a Universal Transponder Immobiliser Bypass Kit in which my installer used my extra key. For some reason, whenever we tried to remote start the car, it would not start. However, when I took the key with the transponder and put it up against the ignition, the car then started. I dont know why it turned out that way. I really would like the remote start feature if we could ever get it work. I purchased the universal transponder immobiliser bypass kit from Pepboys. Maybe the one I used wasnt the best, are there better brands out there?
Old Jun 19, 2004 | 09:46 AM
autogunner's Avatar
So are you saying that both keys work with the new imobilizer and that it just does not work from a distance? Autogunner.
Old Jul 14, 2004 | 01:30 PM
00ML430 Bulldog's Avatar
2000 ML430
Did you get your remote starter to work right??
Old Jul 14, 2004 | 09:24 PM
ML320 Man's Avatar
ML320
No...never did get it to work. I dont know what we are doing wrong. Ive just given up....took too much of my time, money and effort. Its a nice alarm, dont get me wrong. I just wish I had the all the features working.....someday maybe.
Thanks a lot you all!
Old Jul 15, 2004 | 05:15 PM
pointman's Avatar
can't use immobilizer...need to have extra transponder...then itll work 100%
Old Feb 18, 2013 | 12:04 PM
IAMBENZ01's Avatar
01 ml320 and 98 e320
What remote start works with the 01 ml320? I have seen people do the installation but are charging up to 1700.00 (dollars )...that's house or Benz payment.....Any good products forself installation????? I may have posted this wrong
Old Feb 18, 2013 | 06:38 PM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Remote start Install
Mid City engineering has a Module that works well , doesn't need a spare key
Mid city engineering is a Vender on these forms. Arctic Start has a keyless start kit and a module kit. Over at Benzworld.org go to the w-163 forums , They have much better info , on your issues
Cheers _PTEngineering
