Dreaded swirl flap issue!
Old Jan 30, 2019 | 05:48 PM
Jayhughes1984's Avatar
Ml270
Hi all, having some issues with my 2004 270cdi, it’s currently in limp home mode, won’t kick down or anything, I have purchased a good quality diagnostic machine which is showing a few things, have taken some pics of faults that are stored. Main one is p1189-8 M55 inlet port shut off motor check signal line of component M55 for discontinuity? What does that mean?? I have purchased a replacement swirl flap motor As I’ve been advised the motor is knackered but I’m not entirely convinced, although the original motor isn’t working as
I’ve checked. will add pics of the other codes too. It’s had a brand new MAF, egr works fine but have also had it off and cleaned. Any info wouldn’t be greatly appreciated 👍
Old Jan 30, 2019 | 11:12 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
There are too many codes set for any one problem. Erase all codes and restart eng.
Old Jan 31, 2019 | 01:49 AM
Ml270
hiya Maj, I have erased these codes several times but they continue to stay on the machine
Old Jan 31, 2019 | 06:30 AM
Jay, do you need instructions to replace this part?
What part number did you purchase and where did you buy it?
https://www.dictionary.com/browse/discontinuity
Old Jan 31, 2019 | 11:23 AM
Ml270
im good with fitting the motor etc it’s more of what this code means and which one is putting the car into limp home mode. Does it mean the motor is knackered or something else?
Old Feb 1, 2019 | 02:39 AM
Look at all the replacements for this part. You have no choice but to disassemble everything and have a look/see .
Old Feb 3, 2019 | 12:33 PM
Ml270
Update, all sorted, the swirl flap motor apparently blew the 10a fuse that is hidden in the ecu box, replaced motor and fuse, car now working normally and out of limp home mode. Thanks again for the replies Maj it’s much appreciated 👍
Old Feb 3, 2019 | 01:03 PM
Jay, it would be nice to let everyone else know where this hidden fuse is. Take a photo if possible.
Old Feb 3, 2019 | 01:25 PM
Ml270
yeah will do, took me 2 full days of internet searching to find the info and a Merc mechanic advised me about it, will take some pics tomorrow and post 👍
Old Apr 23, 2024 | 11:36 AM
Zaheer343's Avatar
GLK 200cdi 2012
I have same issue in my car
i have same issue in my car please can you tell me the location of fuse
