BAS/ESP - Help
Been reading a few threads on the BAS/ESP issue on this forum, but i couldn't find one that related exactly to the issues that i am having. Appologies if some or part of my issue has been explained in some parts or other threads, but wanted some help on my specific issue and some suggestions.
About 2 weeks ago, when i starting from a stop during normal acceleration I started noticing a mechanical sound, that seemed to come from the left front of the vehicle. Almost like something mechanical was loose, that fell into place once i accelerated. If i would start slow, it wouldn't happen, just during normal or heavy acceleration. A week later, the BAS/ESP light came on at times, and also the ESP light on the center console is blackened out. The light would be on at times, then off. This morning when i started the car and went around the corner, the warning triangle started flashing, and the car automatically started to break by it self. Pretty scary, but i was going slow. And after shutting off the car, and turning it on again the issue disappeared.
I have done alot of fixes here myself, via thanks to people on this forum. But since its breaking related, i am almost thinking to turn the car in to the dealer, as i really don't want that Auto breaking to happen again.
I do have access to quite a few junkyards in my area, and could get parts easily if needed, but wanted to get some feedback here first before i do anything. The W163 model i have is the ML 55 if that matters
Very thankful for any suggestions, and help.
Scan and POST.
The simple things to check -
- Brake light switch.
- Disconnect battery and apply brake for 30secs; Re-initalize the system and then with the suv running, crank the steering wheel all the way to the left and then to the right. This resets the steering angle sensor.
- brake pad sensor
When these lights come on, it can mean that there is a fault with either the brake assist or the stability control.
Attached ESP codes (courtesy of Maj. Dundee)
Went to a local shop and they scanned my car for free, got a lot of codes, but i know that one could trigger another etc. Here are the codes we got, some also seem to have the same code.
C1320 - Undocumented Code
C1120 - ESP Yaw Rate Sensor N/64 of Sensor Signal
C1000 - Control Module
C1022 - CAN Bus: FAult in communication with ME N3/10 Right
C1140 - Steering Angle Sensor
Thanks in advance for any suggestons, or what i should do.
example
example
