P2086 code and P0171 on my 05 ml350
DTC P2086 P0170.
Simpliest checks first....
I'd first check for any vacuum leaks somewhere under the hood, maybe on the backside.
Also there are other things that can cause a lean condition, ie. clogged fuel filter, faulty injector, faulty injector O-ring, low fuel pressure, dirty MAF Sensor.
When you replaced the MAF Sensor, did you remove the air intake tbe? If so, check to see if the clip is broken, Feel under the tube.
Understand that when there is an air intake leak, the ECM will add more gas via the injectors to compensate for the added air. But if the leak is very large, the ECM will only adjust the gas to a certain point and then the codes are stored.
