2002 ml320 abs codes
Old Aug 4, 2019 | 09:46 AM
Sgtspitter101's Avatar
2002 ml320
I need some help diagnosing some abs codes. I have C1529, C1120, C1140, C1314, C1100, C1401.
Old Aug 4, 2019 | 01:49 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
What exactly is the issue (other than the saved codes) - please elaborate.
Old Aug 4, 2019 | 01:51 PM
2002 ml320
I have the abs light and the 2 other lights on also. No symptoms thankfully.
Old Aug 4, 2019 | 10:50 PM
khomer2's Avatar
What other 2 lights on are you referring to?
We are not going to guess at a possible resolution if you cannot provide clear answers and elaborate on your issue.
Old Aug 5, 2019 | 01:15 PM
2002 ml320
My bad. The traction control and stability control lights are on. No symptoms, just the codes i have provided.
Old Aug 5, 2019 | 02:22 PM
khomer2's Avatar
Any other recent past issues that you know of, or changed, that you haven't mentioned yet.
Old Aug 5, 2019 | 04:00 PM
2002 ml320
I just recently aquired the vehicle with these issues. It had been parked for a few months with a dead battery. I tried the steering angle relearn and also reset the codes with a obd2 scanner but they come back within 5 seconds after reset. Would the yaw sensor set off all 6 codes i provided? Or the wheel speed sensor?
Old Aug 5, 2019 | 04:52 PM
khomer2's Avatar
Ok, now we have a better picture of the recent past.
Did you replace the dead battery?
Checked all four shoes and the brake linings and sensors?
Turning the steering wheel end-to-end is correct to re-calibrate the steering angle sensor, AND you still have to drive the suv so the wheel speed sensors send a signal to the CU. Dont have to drive it too far a distance.
This doesnt sound like a BLS issue, but it wouldnt hurt for you to swap in a new one if you like - they are cheap.
Read here and here
Old Aug 5, 2019 | 10:18 PM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Code C1401, with all three lights on, means that the brushes in the ESP pump motor are worn down.
https://www.benzworld.org/forums/w16...ml#post4229913
Old Aug 6, 2019 | 12:51 PM
2002 ml320
Is there a way to jump the motor off the battery in place of the relay?
Old Aug 6, 2019 | 04:14 PM
No because the brushes in the motor are worn down.
Try swapping relay K25. If that doesn't work then it is the brushes.
Old Aug 6, 2019 | 07:53 PM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
I agree its the brushes or check the wire harness. I had some ML cars that had bad brushes some i had that few wires were broken few inches from ABS pump just fallow wires 12' from ABS plug and just check them very good. Both are fairly easy fix if you know what you doing. brushes about $25 or so . good luck
Old Aug 7, 2019 | 10:51 PM
mihir_d's Avatar
2000 ML320 2006 SLK 350
How many miles on your ML? ABS Pump brushes will wear out over time. You can swap out your ABS module with a rebuilt unit, if you don't want to open and work the ABS motor. Swap would cost around $400ish..
Old Aug 7, 2019 | 11:26 PM
2002 ml320
It is a 2002 with 207k miles. It is due for a few things.
Old Aug 7, 2019 | 11:37 PM
mihir_d's Avatar
My ABS motor brushes went out st 220k miles. It will not hurt addressing the ABS motor. The brushes are at end of life by now.
Old Aug 12, 2019 | 07:21 PM
2002 ml320
I have an update. The last 2 or 3 mornings only the bas/esp light comes on until i drive a few feet and then the abs and ets light pop up. Could this be the yaw sensor maybe?
Old Oct 29, 2019 | 11:27 PM
jay4usc's Avatar
2001 ML 320
Anyone in Southern California in here know how to replace the brushes? I can take out the motor out of the car but I’m to confident on replacing the brushes plus i don’t have the tools and work area. I don’t paying someone to replace the brush for me.
Please email me if you are interested jjs2013@icloud.com
Old Nov 4, 2019 | 08:05 PM
jay4usc's Avatar
2001 ML 320
Mr. Dundee. Thanks for the info on the relay. I just tested my problem and it’s the relay that I need to replace. I’ve been searching online and can’t seem to find the Siemen brand which is what is what it’s in my car. Do you have any suggestion on which brand and where’s the best place to purchase instead of the dealership? Thanks for your help.
Old Nov 5, 2019 | 04:04 AM
Right here.
Amazon Amazon
Old Nov 5, 2019 | 12:47 PM
jay4usc's Avatar
2001 ML 320
Thank you sir
Old Nov 5, 2019 | 04:16 PM
Thank you sir
Any time.
Old Nov 5, 2019 | 06:09 PM
jay4usc's Avatar
2001 ML 320
For those looking for someone to rebuild their abs pump, I found a company in California that rebuilds them. All you have to do is mail in your old one and they charge $249 to rebuild it. Below are links to their eBay add and also their company website.
https://www.ebay.com/itm/REPAIR-KIT-...QAAOSw3wVahIjU
company name= Module Repair Pro Inc
https://www.shop.modulerepairpro.com
Old Nov 6, 2019 | 04:50 AM
mihir_d's Avatar
I got a rebuilt unit from them and returned my worn out ABS pump unit for a core credit. I can vet for them. 2 years, since swap, my truck has had no ABS codes come anymore...
