key off issue
Old Sep 26, 2019 | 10:52 PM
Kevin Costello's Avatar
2004 Mercedes ML350
key off issue
I have a 2004 ML 350, the stereo and the SRS light stays on with the key off, What could be the cause?
Old Sep 27, 2019 | 01:14 AM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Welcome Kevin,
I don't think the 2 are related.
For the srs light staying on, check under the rear seats for a disconnected buckle switch.
Do you have a scanner?
If so, what type?
You'll need a professional-grade foxwell or an autel scanner to be able to read and clear srs codes.
For the radio, our 99 c230K radio stays on with the key off. Removing the key, it turns off when the door is opened.
For our 02 w163, radio only comes on when the key is in position 2, and when turned off, the radio dies out.
Test yours for the configuration as Im not sure how the 04 w163 radios are setup
Old Sep 27, 2019 | 04:44 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
Is it with the key in the off position or is it the key out of the ignition?
