Semi automatic shifting (on automatic ML320 W163) ) doesn't work anymore
ML 320 2001
Hey everybody,
My automatic ML320 (W163) has trouble passing gears lately. It goes pretty high in rpm before it shifts to next gear. Especially when the engin is cold. Theres a strange smell from under the car (not really in engin compartment) of something that heats up, though not like burnt rubber, but I'd almost say acidish- or sulfurish-like smell.
After a while all seems to work ok.
Today I also noticed that the manual shifting (semi automatic shifting?) doesn't work.
Although there's no cracking sounds or whatsoever and the car runs smooth.
Is this more like an electronic or a mechanical problem?
Thank you for your ideas and help,
Cheers, Den
Cheers, Den
Den,
You need to have the codes read - Modules: ECM, Traction Control Module & Transmission control module.
Post here.
When was the last time you changed the tranny oil and filter?
Post here.
ML 320 2001
Hi khomer,
I should go see my electrician mechanic for some readings before I can tell you any results.
I bought the car 9 months ago, drove about 4000kms with it and I've never changed the tranny oil, nor the filter. The car driven 155k total.
I thought tranny oil didn't ever had to be changed though on ml320.
Cheers Den
Cheers Den
Hi khomer,
Cheers Den
Cheers Den
I have ocean water front property for you - 100 acres with all under grounds services, sewer, water all in place.
Just off the Clark County Wetlands.
A steal of a price....for you...only $3kusd- one time, time limited offer.
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Always DO fluid changes regardless when you buy a used car (if no true records of a fluid change)......
Do a search on this topic - MB did at one time claim a no tranny oil filter change....that all changed in their service reports.
ML 320 2001
Ok, I will look for that,cheers.
Now I just came back from a ride this morning (live in Australia) and everything works as ever. As I said, it's not all the time. Couldn't it therefor be something electronic? Or the spark plugs, even though all cylinders seem to work properly?
There's something else that happens also... :
When engin (cold), at take-off, I give a certain amount of gas and it doesn't take off as it should (meaning for the amount of gas it should go faster) and then at once it spurts off like it takes at once the gas I asked for... This symptom seems very much related.
For all we know, it could be as simple as a crack, clogged or displaced vacuum line. (which btw, with the age of our w163s, vacuum lines do crack and disintegrate without you knowing about it until you scan and "physically" check all lines...)
I recommend you take plenty of photos for reference before and after.
Inspect first, and prepare, in advance, having replacement lines.
EDIT:
No real good info on the lines but this should assist you > https://www.benzworld.org/threads/20...lease.1702084/
ML 320 2001
When I just normally drive in automatic mode and I push the lever to the manual shifting mode, the gears don't change. The numbers of the gears change on the dashboard, but it doesn't change gears in real.
Remove the console trim and examined the trans module to see if you see anything unusual?
ML 320 2001
You will need to scan your TCM (trans control module and post any saved error codes.
LHD - TCM is located DS footwell just above the transmission tunnel at the firewall (shown in this video);
ML 320 2001
Thank you for all the good explanations. When I get to scan the module, I'll post here.
Can it be scanned as with the same tool as the scan which you have to plug under the steering wheel?
