1998 ML320 Shredded belt
ml320 1998 w163
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
To make life interesting, my ML320 had it's belt decide to shred on me, luckily only a block from my house. That was an interesting experience. Check battery indicator comes on and loss of power steering. Otherwise would have never known. Ordered a new Gates K060942 Belt to replace it.
So advice on replacing the belt. If I understand correctly, route the belt around the (passenger side pulleys) Generator, Coolant fan, and Guide Pulley 1 first. Then around the (driver side) power steering pump and crankshaft. Next loosen the tension-er with a 17mm ?? socket and route around the AC Compressor. Is it that simple or am I missing anything?
Still trying to figure out if there are any other issues. I checked pulleys 4 & 7 by spinning fast and # 4, "Guide Pulley 1 seems to spin freely". Can I get confirmation that this must be replaced?
If so, I believe you take off the plastic center cover w/ small screw driver. Then with a T50 torque, it can be removed. I believe this is GATES Idler Pulleys 38082. Is all of this correct?
Any next steps on what else to check?
Thank you!
Thank you!
Hi Scott,
This link, hopefully should assist you![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
https://mbworld.org/forums/m-class-w...dded-belt.html
ml320 1998 w163
Hi khomer2.
I had read that post and it did help a lot. I also watched a couple of videos but they were of different models. I was also looking for some confirmation on a few things like the pulley 4 free spinning means it needs to be replace before ordering and replacing the part.
Thank you.
Thank you.
ml320 1998 w163
Hey Maj. Dundee.
On the technical diagram P13.22-0234-01 regarding the 6-groove single-belt drive with AC compressor, it list the Idle Pulley as the #4 Guide Pulley 1. So I was referencing that.
Thank you for the torque specs for the Idle Pulley. :-)
ml320 1998 w163
I needed it for #4, the Guide Pulley #1 / Idle Pulley. But I am good now. It is all back together. First time replacing a belt and it was a heck of a lot easier than I would have thought.
Thank you
Thank you
