Backlight on Motorola v60 always on
Old Jul 31, 2004 | 03:02 PM
rbetz's Avatar
2005 ML350
After having the hands free communication system installed a couple months ago, I have discovered that the backlight is always on when the Motorola v60 phone is attached to the cradle (it does turn off if you take it out of the cradle to carry with you). Yesterday I took my vehicle in for the 3000 mile checkup and asked them to look into this. My main concern is that the phone gets rather warm/hot the longer the phone is in the cradle with the power on. Dealer tells me this is normal, and that other MLs do it as well. I'm concerned that, since this phone is about $600 to replace, that the heat generated by it over the long haul will have me replacing the phone much sooner than I will have wanted to. Has anybody heard anything about this?
Old Aug 1, 2004 | 04:39 PM
bigcatny's Avatar
98ML320
Most phones have an option to adjust the setup for different situations. I know the V60 could be setup different ly for headphone and for FM radio adapter so I'd suggest looking in the setup to adjust the backlight setup.
Also, it's normal for the phone to heatup in the cradle as it's busy recharging which will cause heat. If the backlights on it'll definitely cause more heat. Can't imagine you'll still have that phone by the time anything burns out as it's already a very old model phone.
Old Aug 1, 2004 | 08:53 PM
SUNILP's Avatar
2015 E250D
My nokia has an option to leave the light on or off when In the cradle. I leave it on and it's been on for 1.5 years now and no problems.
Old Aug 4, 2004 | 04:16 PM
benzboy's Avatar
SL500 E320 ML350
I think you can surpress the backlight by scrolling through the setup menu. That should do it in or out of the cradle.
Old Aug 4, 2004 | 04:31 PM
rbetz's Avatar
2005 ML350
Yep, tried that
I've went through all the settings on the v60 and still haven't had any luck getting the backlight to stay off . . . . unless I'm missing something.
Old Aug 7, 2004 | 02:40 PM
nimit's Avatar
"I'm concerned that, since this phone is about $600 to replace, "
*scratches head* isnt this an old phone?
the new motoroloa i830 is only 299.99 and that is without a new contract...maybe its just me?
Old Aug 7, 2004 | 03:01 PM
rbetz's Avatar
2005 ML350
Backlight Problem
I just purchased the hands free communication system from Mercedes in May. That's the phone that came with the system. No other options were available or offered. You can't just put any phone in the system, you have to put the Mercedes version in for it to work.
